Question about Millennium Sofsource Mathematics Probability & Statistics for PC
If i had 2 blue balls and 4 white balls what is my chances of getting a white then a blue ball?
  • 76 Answers
There's a 66% chance to get the white ball, and then a 40% change to get a blue one..
so totally you have 26% chance to get your combination if i'm right
Posted on Sep 25, 2009
Are rugby games the same length as soccer games?
Rugby games are unique in that each one consists of two forty minute halves to make a total of eighty minutes game time. Like in soccer, some games can go slightly longer if no one has scored or if there are penalties.
Jan 14, 2013 | Rugby
Tip
BOWLING TIPS
<b>How To Scare The Crowd:</b> <br /> <br />Start the regular bowling motion, and let go of the ball on the back swing. The ball will fly backwards, and the crowd will jump and scream.<br /> <br /> <b>How To Throw Your Ball Down The Wrong Lane!</b> <br /> <br />You can start the ball on another track by holding down the A button, and dragging to the right as you can. The ball will go in the alley side of their own.<br /> <br /> <b>How to Amuse the Crowd When You Bowl:</b> <br /> <br />You can make the crowd laugh. Move to the sewers in your lane, turn into the opposite lane, and bowl the ball has crossed the barrier between the lanes. The ball will go by the wayside in the opposite lane, and people laugh.<br /> <br /> <b>How To Get A Special Bowling Ball:</b> <br /> You must get to the pro-level to unlock the bowling ball that has diamond designs on it.<br /> <br /> <b>How To Change The Color of Your Bowling Ball:</b> <br /> <br />When the screen goes black for bowling, hold down the control key positions in the following colors specified bowling ball: Control Pad Up Blue Ball Control Pad Right: Gold Ball Control Pad Left Red Ball Control Pad Down Green Ball .<br />
on Jan 02, 2011 | Video Game Consoles & Games
How many balls are used in billiards?
There are a total of 16 balls used in the game of billiards. 15 colored balls and one white ball (cue ball). Balls numbered 1-7 are solids and 9-15 are stripes. Then there's the 8 ball (black ball) which is neither a stripe/solid.
Jul 25, 2012 | Sport & Outdoor - Others
Where can i get replacement white disc's for my 2
where can i get replacement white disc for odyssey 2 ball putter?
Dec 14, 2009 | Odyssey Steel 2 Ball Srt Putter
I get this slime around tub and lid...any solutions
try using a grunge ball it attracts the excess body oils. also check chemicals. maybe shower off b 4 u use tub
Oct 12, 2009 | Comfort Line Spa 2 Go Portable Spa with...
Dishwasher will not drain all the water out
If this is a GE or Hotpoint dishwasher the solution is fairly easy, but a pain. GE (Hotpoint is the same company) has been using a small plastic ball that prevents backflow of the water. A lot of times that ball migrates and doesn't allow the dishwasher to drain. To get to this, you need to remove the two 1/4 inch hex head screws in the food trap basket, the 1/4 inch hex head screw from the spray arm, and use a small screwdriver to pry a clip at the back of the spray arm up to remove the spray arm assembly. Siphon as much water from the dishwasher as possible because you'll be opening up the plumbing below. Turn off your electricity to the dishwasher and pull it out of the cavity. Directly behind the motor is a large manilla-colored "tank" with a large hoseclamp holding a white union with two smaller hoses coming off it. Loosen and remove the white union from the large tank and the ball should fall out. Replace the white union, tightening the hose clamp and drop the ball back into the tube on the left side of the food trap basket. Put it back together and test run.
Sep 10, 2009 | Dishwashers
Stuck on puzzle 94 (Get the ball out) 4 Can anyone help. Game Nintendo DS Professor Layton and the Curious Village
094 Get the Ball Out! 4
1. If you're persistent in your efforts, you'll eventually get the ball to
the hole, but there are tricks to streamline the process.
The large block in the puzzle is relatively limited in range of
movement, so you're going to have to do more work with the smaller and
more maneuverable blocks. If you focus on them and plan out a route,
things should go smoothly.
2. If you move the green block on the right down, you can fill the space
you create with a purple block from the right. If you can pull that off,
you'll be able to move the blue block in the upper left, which will
allow you to move the red ball out of its slot.
It may seem complicated, but give it a try.
3. There is no set solution to this problem.
Here's one way to start out. Move the lower-left purple blocks, then
slide the lower blue block to the left.
Next, drop the green block on the right down.
The rest is up to you.
However, I have found the following sequence if you can follow it to get it done in 21 moves:
Purple block = P
Yellow block = Y
Green block = G
Red ball = R
(l)eft (r)ight (u)p (d)own
P[d],P[l],B[l],G[dd],P[dd],P[rd],B[rr],R[dr],G[uu,Y[l],P[rd],
B[d],R[rru],B[ul],R[ddl],P[uuu],R[rd],P[u],R[l],G[uuu],R[rdd] = 21 moves
Thanks and please take a moment to rate as fixya.
Feb 23, 2009 | Nintendo Professor Layton & the Curious...
Discovery ball
Battery Installation:
1. Requires 3 AA (called LR06 in some countries) alkaline batteries.
2. Locate the dial on the end of the ball, and unlock the dial by using a flat instrument,
such as a screwdriver or coin.
3. Holding the ball in both hands, twist sides in opposite directions and pull the blue side away
from the center.
4. Locate the battery door on the inside of the white center piece.
5. Remove the two screws in the compartment door and install new batteries as shown in the
polarity diagram (+/-) inside the battery compartment.
6. Replace battery door securely and reassemble ball before use.
Feb 20, 2009 | LeapFrog Discovery Ball
Zenith cov. problums
THose are G2 settings they have to be adjusted to certain voltages. You can ball park the adjustment by setting conrast, ad brightness levels to 50 percent. Shut color level to its lowest setting then adjust each screen control to achieve a good black and white picture not too bright. then turn your color and other controls back up. This should get it ball parked for you. Anything further and you would need the service manual. If you'd like a service manul let me know I have a link that has them at a cheap price and provides free support with them.
Jan 14, 2008 | Zenith IQC50H95W 50" Rear Projection...
Millennium Sofsource Mathematics Probability & Statistics for PC Logo
93 people viewed this question
Top Millennium Computers & Internet Experts
Bapco
Geoff White
Geoff White
Jay Plesset
Are you a Millennium Computer and Internet Expert? Answer questions, earn points and help others
