Question about Canon imageCLASS MF6550 All-In-One Laser Printer
The top paper feeder will go about half way and stop feeding. How can this be repaired?
  • 23 Answers
The feed rollers may be worn out and need replacement. they are quite small and do not last very long.
Posted on Sep 25, 2009
Canon MP530, would only print half of a page then quit and give me error message 5700. I would pull the paper out and shut down and would start and print only half of a page and stop. I would take out...
This error is referring to the ASF assy (Assembly frame which means the paper feed section)
This paper sheet feeder assy is a extremley complicated piece and is therefore not really repairable. You will need to take the machine to a canon repairer for a new assy sheet feeder to be fitted. It takes a trained engineer about 2-1/2 hours to fit one as the whole machine has to come apart and the new feeder has to be aligned while fitting. Its a job i always hate having to do. You dont have any other options i am afraid. Srri to bring you such bad news.
May 24, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
Need replacement process for paper feed roller in scanner compartment.
On the doc feeder there are 2 arms that go down into the machine. UNPLUG machine first. You squeeze them carefully and rock the doc feeder backward. It may take some manuevering,
Once you have separated the top half of doc feeder, you will see a wire harness going into the upper half, CAREFULLY unplug it. There are several screws holding down the cover over the bottom half, remove them and again carefully separate this cover from the main body.
Once this is done you should be able to replace the feed roller. One note, while you have it this far apart you ought to change the separaetor pad in the top half.
If this helps you, please log in a vote for me, thanx
Feb 07, 2011 | Brother Fax-1360 Plain Paper Inkjet Fax
Minolta DiAlta model 151f, when i try to use the automatic paper feed on the top of the machine the paper goes in about half way then stops then a message comes caution original doc jam
Try cleaning the pickup wheels that pull the paper into the feeder. There might be an electrical sensor problem also that is not sensing the right paper size. So lets start with cleaning the feeder
Jan 04, 2010 | Minolta Office Equipment & Supplies
Paper not fully feeding from paper tray. stops
  • Check for jams
  • Make sure all rollers are rolling and feeding
  • Make sure you using the manufacture required paper weight.
If none of the above applies to your issue you might have a bad feeder the paper is getting jammed mid way or there could be something inside blocking it half way thus your printer will need good maintnance.
Please do leave positive ratings for your free solution today.
Nov 17, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
"check paper" error appearing
ON THIS MACHINE THERE IS PAPER FEED ROLLER THAT NEEDS TO BE REPLACED THE TOP HALF OF THE FEEDER MUCT COME OFFF TO DO THIS OR YOU MAY HAVE A SENSOR OUT OF WACK WHICH IS UNDER THE FEEDER. IF YOU ARE GOOD WITH HANDS YOU WILL FIND IT GOOD LUCK
Jan 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Cannon imageclass d660 auto feed stopping 3/4 way through
There are some small plastic pieces in this feed that can do this. This is an older machine, the whole top feeder can be replaced for $150.00 Its $100.00 dealer cost. And they will want an hours labor.
If that doesnt sound good I would buy a new machine.
Dec 23, 2008 | Office Equipment & Supplies
Top paper feed jams
if your feeder is jamming you need the roller & pad replaced and usaaly the internal feed roller cleaned this is a repair that should be done by a sharp tech about a $150
Jun 30, 2008 | Sharp AL 1631 Copier
Automatic document feeder
you have to replace it if cleaning doesn't help.
look for the seperation tire or pad if it picks up the paper from the top first then the sep is on the bottom and vice versa. Clean that on really good this is the one that seperates the paper and stops it from feeding more than one sheet.
Oct 21, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Canon imageCLASS MF6550 All-In-One Laser Printer Logo
144 people viewed this question
old marine
old marine
