Question about Jenn-Air Ovens
Have jenn-air double oven model #ww27430 cannot get lower oven to broil or cancel whenpressing control panel buttons for these commands no "beep" happens as with other commands. What part do I need? Membrane Switch?
Gigatech
  • 259 Answers
SOURCE: Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Posted on Dec 09, 2007
  • 3422 Answers
SOURCE: Jenn Air double oven keeps beeping
HI,
The problem is with the faulty relay board or wire harness harness.
There are no home remedies for this problem.The only solution is to get it repaired.
Posted on Sep 17, 2008
  • 5 Answers
SOURCE: Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Posted on Dec 11, 2008
jumptrout51
  • 3361 Answers
SOURCE: jenn-air ww30430w dual oven, lower oven, lower
Most likely a bad element. Turn off the power to the oven. Remove the racks.
Use a phillips screwdriver or 1/4 inch nut driver to remove the mounting screws at the back of the oven cavity to remove the element. Carefully pull the element out and remove the wires. Do not let the wires fall back into the holes.
Use a volt meter set for continuity. Touch one meter lead to one terminal on the element. Touch the other meter lead to the other terminal. If you get NO reading the element is bad.
A new element will correct your problem.
If the element reads as good you have a wiring problem or a bad control.
Posted on Jan 03, 2010
taran_2005
  • 10515 Answers
SOURCE: Jenn-air electric double control does not work - clock is on
Disconnect the Power Supply for few minutes, say 30 minutes and then Turn the Oven ON.
Do you see any Error Message?
How old the Unit is?
Do you have any Experience to Fix this?
Do you have all the tools?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 30, 2010
Most of the buttons on the panel do not respond when pressed. incl;uding, convection, setup, rapid preheat
Are the oven doors locked as well, check if the front panel lock is active. Press and hold both the upper oven Cancel and Cook & Hold buttons for 3 seconds (or a bit longer). (Off should disappear from the display and the Lock indicator will flash.)
If that doesn't help, try pressing Cancel. Then try pressng the Cancel and Cook&Hold keypads together. If this doesn't help, then the control panel or the control itself is damaged and probably needs to be replaced. (Touch pads like this have electrical contacts on a membrane that is impossible to fix long term by cleaning the unit.)
For a parts list and prices see: http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Wall-oven-Parts/Model-JJW9130DDS/1266/0125300/M0603043/00001?blt=06&prst=&shdMod= or http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170052&diagram_id=28429593 . Specifically part 1A and 2 are suspect. The control panel is the more likely part to fail (much like a membrane keyboard).
Most Jenn-Air appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US . Fill in Consumer and then the model number and press the right arrow button. The direct link to the manual is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10176680.pdf .
I hope this helps.
Aug 11, 2011 | Jenn-Air JJW9130DDS Electric Single Oven
HI,
Sep 17, 2008 | Jenn-Air Electric Double Oven
My oven door is locked closed. Also, it reads F8 and beeps. In order to stop the beeping, the cancel/off button must be hit. When I do that, the fan turns on for about a minute and then stops and goes back...
The control board runs self checks about every 10 seconds to check the oven codition,and what the F8 error code means is it has detected a problem with the control board itself and it needs to be repalced
Gene
Aug 04, 2011 | Jenn-Air JJW8430D Electric Double Oven
I have a double oven. Model WW27430. The top oven will not heat. The bottom is fine. I was told that is was the relay board. which I replaced and I am still having the same problem. Could both...
Looking at the schematic I see 2 possibilities:
1. I think the most likely cause is a failed "limit switch" aka "thermal fuse" aka "temperature cutout". For each oven there is a limit switch that feeds power to both elements. So the upper limit switch is probably tripped which would kill power to the upper bake and broil elements. The limit switch is usually located on the back wall of the oven cavity.
2. There are a relay board for each oven. Be sure you changed the right one.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | Jenn-Air WW27430P Stainless Steel Electric...
JennAir F8
Check out www.appliancetimers.com They can rebuild your clock for around $100. A new Jenn-Air is like 2 grand.
May 21, 2010 | Jenn-Air JJW8530C Expressions Collection...
Hope i helped you.
Jan 30, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Error code F1
I had the same problem and found this post:
http://fixitnow.com/wp/2006/03/11/maytag-amana-jenn-air-and-magic-chef-range-f1-codes/
The oven had been cleaned earlier in the day and the touch pad ribbon connector was shorting. I cleaned it with rubbing alchohol and blow dried the whole board for good measure. Hooked everything back up and haven't had a problem since.
Jun 08, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
99 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
