Question about Perlick FR24 Stainless Steel
I have an older Perlick kegerator that only gets
I have an older Perlick kegerator that I got used and only gets down to 41 F on coldest setting, 50 F on warmest setting. All temps taken with calibrated lab thermometer in large glass of water. Condenser fins are clean, compressor cycles, evaporator fan runs constantly. Is it the thermostat? I cleaned off the fan blades for the evaporator and wondering if the pitch of the fans blade has something to do with it.
  • Northeast Cooling LLC
    Northeast Cooling LLC May 11, 2010
    Might be the tstat. Could be low gas. The condensor should be hot on top and slightly warm at base. If you are handy try this. Unplug unit. Pull tstat out enough to get to wires. Pull wires off tstat and jump togeather. Let unit run like that for 2 hrs. If it gets nice and cold you need a tstat. Northeast Cooling llc can provide the part.
How do I get my maytag side by side refrigerator model# msd2756geq to cool down below 50
first turn your refrigerator temp setting to 1 then wait for the compressor to kick off, this will send the unit into defrost mode, and most units take between 1 to 2 hours to acclimate(get tempered) correctly. after a few hours gradually turn your unit towards 9 until the compressor kicks on, when it does , stop turning the knob, it will acclimate again, 1-2 hours (some units can acclimate in 15 minutes) check your unit temp and do not use the unit if it won't cool down to 43 or less degrees, you run the chance of food poisoning. hope this was helpful.
Aug 01, 2014 | Maytag Refrigerators
How do I get the right temperature in a beverage air BM 23 Kegerator
either a problem with the thermostat or the probe for it has been dislodged and getting a false temp reading
May 18, 2014 | Beverage-Air BM23
Resealing lid on a Beverage Air DD58 kegerator
The only way I have found to seal those tops back down is with 100% silicone caulk, NOT LATEX OR BUYTAL, silicon.( We use 3m.) Then hold it down with cinder blocks for at least 24 hours then you are in business.
Mar 21, 2014 | Beverage-Air DD58 Beverage Cooler
Replacing true kegerator parts
no use a Ranco p# A12-700 make sure the capillary is in the coilto sense the temp and set it to 1.5 on the knob. any colder and it could get too cold . you may be able to set it at 2 but be careful. it is a constant cut in at 37 degrees coil temp. the box temp will drop to usually to 28 or 29 at cut out.
Dec 31, 2012 | True Direct Draw Systems: Kegerator...
Bought a used danby DKC645BLS kegerator it is missing the co2 tank bracket that mounts on the back of the kegerator, where can I find one. Also the psi is set at 10 on the co2 tank and the beer comes out...
mark pasieka has an inventory of refridgeration, kegerator and bar related parts (as well as everything else)... he has this bracket in his warehouse right now... at least one... he also has tanks of CO2, oxygen acetalyne anything you may need... mark.pasieka@gmail.com
Oct 06, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Older Superior Brand Kegerator Freezing
Sounds like the fan can be running backwards. I'm not sure of you exact model, but it has to match the air flow of the original unit. Do you remember? Some manufacturers use reversable motors and are some what easy to reverse.
Good luck and hope this helps.
May 08, 2009 | Danby DKC645BLS Compact Beverage Cooler
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Perlick FR24 Stainless Steel Logo
273 people viewed this question
Top Perlick Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Perlick Refrigerator Expert? Answer questions, earn points and help others
