Question about Jabra BT160 Wireless Headset
My jabra BT160 won't charge
I have a BT 160 that I've used for over 2 years. I purchased 4 others for my family and they have all worked fine. A few months ago I purchased 4 more to have for backup. I recently opened a new one and when I plugged it in to charge it blinked on and off and stayed off. I left it to charge and it won't charge. I tried 2 more and they won't either. Is there anyone that knows what to do?
I had the same problem with mine. the problem is with the completely empty battery.
solution is to disassemble it and force charge the battery inside.
you have to cut any usb cable leaving the side which connects to pc and remove the insolation from red and black wires. connect them for few seconds to battery soldering points on jabra board (red to red, black to black, sometimes you have to scratch the solder a bit if it oxidized a bit). once you see the light you can start charging it normally.
Posted on Sep 20, 2010
You can use ANY USB cable, doesn't have to be one that came with the headset. Just cut off the end opposite the end that plugs into the computer. Separate the RED and BLACK wires, and while the cable is plugged into the computer, attach those wires to the red and black wires in the headset. Hold for a couple sec, then you should be able to charge it normally. Don't forget to remove the two screws under the plastic cover to get to the inside.
Posted on Nov 26, 2012
How can you "force charge" it? my battery doesn't come with a computer outlet; instead you have to connect it directly to the wall, and it doesn't do anything! it has all the same problems you mentioned above, i need help!!!
Posted on Apr 03, 2012
Need Operating Manual for Jabra BT 160
You can download the required manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Feb 07, 2010 | Jabra BT160 Wireless Headset
How do you put the device into discovery mode
Before you use your Jabra BT160, you need to pair it with your mobile phone. 1. Put the headsetin pairing2 mode Make sure that the headset is on. Press the answer/endbutton and press the volume up (+) button at the same time, until asolid blue light comes on. 2. Set your Bluetooth phoneto ?discover? the Jabra BT160 Follow your phone?s instruction guide.This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menuon your phone and selecting the option to ?discover? or ?add? aBluetooth device 3. Your phone will find the Jabra BT160 Your phonethen asks if you want to pair with it. Accept by pressing ?Yes? or ?OK?on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros).Your phone will confirm when pairing is complete. In case ofunsuccessful pairing, repeat steps 1 to 3.
USER GUIDE
Jan 03, 2010 | Jabra COMMUNICATIONS BT160 Bluetooth...
I do not have manual for jabra bt160 how do i connect to phone
Wear it how you like it 4
5
English
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2 )
For optimal performance,wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight.In general,you will get better performance when
there are no obstructions between your headset and your mobile phone.(See fig.5 )
Answer a call
Tap the answer/eend button on your headset to answer a call
End a call
Tap the answer/eend button to end an active call
Reject a call (DDependent on your phone supporting this feature)
Press the answer/eend button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (ssubject to phone
settings) automatically transfer to your headset
Activate voice dialing (DDependent on your phone supporting this feature)
Tap the answer/eend button. For best results, record the voice-dialing tag through
your headset. Please consult your phone ’ s user manual for more information about
using this feature
Redial last number (DDependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+or – ) to adjust the volume (See fig. 1 )
How to...5
1. Put the headset in pairing 2 mode
Press the answer/eend button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘ discover ’ the Jabra BT160
Follow your phone ’ s instruction guide. This usually involves going to a ‘ setup,’
‘ connect ’ or ‘B luetooth ’ menu on your phone and selecting the option to ‘ discover ’
or ‘ add ’ a Bluetooth device.** (See example from a typical mobile phone in fig. 4 )
Pair it with your phone 3
English
Turn on your headset 2
Press the answer/eend button to turn on your headset
Press and hold the answer/eend button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
The Jabra BT160 is easy to operate. The answer/eend button on the headset performs
different functions depending on how long you press it.
Instruction:Duration of press:
Tap Press briefly
Press Approx: 1 second
Press and hold Approx: 5 seconds
Getting started
Your phone then asks if you want to pair with it. Accept by pressing ‘ Yes ’ or ‘ OK ’ on
the phone and confirm with the passkey or PIN 3 = 0000 (44 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
http://www.jabra.com/Sites/Jabra/UK-uk/support/Pages/JabraBT160.aspx
It is all in there www.jabra.com
ARTGIRL
Jul 18, 2008 | Lands Phones
CHARGING My Jabra bt160
I think something's goofy with these headsets. I bought 2 of them recently (one for me and one for my g/f). Within a week or so, she told me hers just "died" - and she couldn't get the blue light to come on when it was plugged into the charger.
Mine acted dead too, just a day or so before she told me about her problem. On mine, I think I just held down the "volume down" button and the main button at the same time for about 15 seconds and it appeared to "reset" it. That apparently didn't work for hers, but oddly enough - after a few days, we plugged it into my charger and it started working again!
Dec 09, 2007 | Jabra BT160 Wireless Headset
My Jabra BT160 won't connect to my Nokia 6103 why?
hold the on/off button and the + button for 2 min. If you fail at the first time. Try again, until you see the blue solid light. Search again in your phone, you should see Jabra bt160. Enter 0000 at the passcode. Good luck
Nov 07, 2007 | Jabra BT160 Wireless Headset
Jabra BT500 will not power on or charge
I would also like to know if you find a fix for this problem. I have the BT500 and it will also not turn on.
Sep 17, 2007 | Jabra BT500 Wireless Headset
Jabra bt160
hold the button down for a long time
Apr 17, 2007 | Jabra COMMUNICATIONS BT160 Bluetooth...
Jabra BT160 Wireless Headset Logo
848 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
