Question about Family Care HM1555 Humidifier
What do u do when some one keeps hurting you & you try to be nice to that person and they keep hurting u over and over
  • 546 Answers
Forget them & move on--you deserve better
Posted on Sep 23, 2009
Unclog personal humidifier doesn't work
If this is an ultrasonic humidifier, in the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 25, 2015 | Humidifiers
Aprilaire 760 keeps running
Is this a newly installed unit it sounds as if there's a wiring issue. Could you show a picture of the wiring terminals. If this is not a new install try turning of your furnace fan.
Nov 02, 2014 | Aprilaire 700 Humidifier
My vaporizer keeps blowing my fuse
it has a short in it. if you are electrically minded you could open it, and try and find where, (probably an element problem)
Nov 12, 2013 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I have a HE265Ahumidifier it keep burning out transformer whats wrong
Hello, usually the transformer will burn up when the amp rating of the transformer is being exceded or if there is a short in the low voltage wiring
Dec 09, 2011 | Honeywell HE360A1027 Whole House...
How far do I need to open the water value to keep the filter wet but not dripping on my cellar floor ?
Sorry to read about your problem, I hope this helps you out.
you have a defective water inlet valve, leaking in water, or you water full sensor is defective.
you should be able to keep the water all the way open, with no problem.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Aprilaire 550 Humidifier
Humidifier creates film on everything in the room it is in.
the white film is just dust particles from the unit. it's also a bit of condensation that is building up. the particles are not harmful. but it's nice to keep it clean after every use. also the film is coming from the vicks. that is normal. so nothing worry about as far as harming the childs air or anything.
Apr 27, 2009 | Vicks V4500 1 Gallon Humidifier
Water runs out of humidifier drain line constantly(rushes out)
Most modern humidifiers use a constant drain to flush mineral deposits, and to keep the water fresh at all times. This keeps the unit from holding standing water. This keep the water fresh and prevents mold spores from infesting the air in your home.
HVAC Teacher
Jan 27, 2009 | General Filters 1099-LH Humidifier
Furnace keeps running, no heat
The pressure switch is not allowing the igniter to heat up. Pressure switch is blocked or the flue is blocked. Take the draft fan off and inspect the flue. Also inspect the rubber hose connecting the fan and pressure switch make sure the ends are tight. Make sure the hose is clear and not restricted. And the pressure switch sometimes is position sensitive. I don't think it has been moved or anything. And very rarely do they go bad.
Dec 02, 2008 | Honeywell Power Humidifier: Furnace...
Family Care HM1555 Humidifier Logo
50 people viewed this question
Top Family Care Humidifiers Experts
Mack Baxter
Dennis
Are you a Family Care Humidifier Expert? Answer questions, earn points and help others
