Question about Acer Aspire 5735 Notebook
Yellow-flagged microsoft network adapter tun now disappeared
The device manager showed this device was yellow-flagged, so i disabled it, becuase of all the msgs that came up to instal a new driver (however that file is never found)
i attempted to reload the software driver using a vendor of device drivers - but the device has disappeared!
    President:
  • 2,666 Answers
Acer supply the drivers FREE as does every other manufacturer.
http://www.acer.co.uk/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3734&sp=page15e&ctx2.c2att1=17&miu10ekcond13.attN2B2F2EEF=3734&CountryISOCtxParam=UK&ctx1g.c2att92=122&ctx1.att21k=1&CRC=2980211862
I suggest you download them all and save to disc for futrue reference.
Posted on Sep 23, 2009
    Brigadier General:
  • 4,044 Answers
Start the computer and press the F10 or F8 button before the windows screen opens. Select repair startup and let teh system try to self repair if you have vista. If you have XP, then insert the installation CD and boot from teh CD and select repair. After doing either of these if the device is still not present the best action I can think of would be an OS overright if you have XP. That is where you re-install XP and SP1 and SP2 over your current XP installation in the same Directory. This will save any programs you have installed and your personal work. You could try disconnecting the device and starting the computer in safe mode and then remove the device in safe mode if it appears and then restart the computer. After the computer successfully starts, turn it off again and then connect the device and reboot and go through normal installation of the device.
Windows 8 Updates disabled WIFI connections
look in the device manager an see if there is a driver loaded for the network devices
if not then see if you can find a driver on the makers website
see that the wifi is not disabled or turned off
May 09, 2015 | Computers & Internet
Tun miniport adapter#2
Hi, it sounds like you have to install the proper drivers. Once you do that the flag should go away and the adapter will work.
Robert
Oct 19, 2013 | Computers & Internet
Device manager problem!
It sounds like Windows is not recognizing the digital signature of the drivers. If they are the current Dell drivers, you can simply ignore the flags.
If you are bothered by them, you can try removing the device from the D.M. and re-installing to try to resetting the digital signatures. (this may not remove the flags)
Mar 26, 2010 | Dell Inspiron 1501 Notebook
Via rhine ethernet adapter has disappeared.
try to go to device manager and check if on your adapter is a yellow question mark if it`s there that means that your lan driver have been uninstalled or try to goo in network connections and see if the lan card is disabled
Mar 14, 2010 | Twinhead SlimNote N12PI Notebook PC
Microsoft ISATAP adapter #2
Disconnect your device and any other external devices.
Re-boot the machine in safe mode and check the device manager for flags.
If you see other devices or flags, red or yellow, remove them.
Re-boot the 6000 and allow unit to run a normal boot.
Check device manager again for flags.
If you are running VISTA, type msconfig at search and in center of page, look for add or remove programs. Highlight and hit the lunch button.
Find your TV tuner program and remove it.
Close out the utility and reboot the system.
Check your device manager again for flags.
If OK re-install hardware and drivers.
Reload the program. If you still have problems, check microsoft for updates under drivers
Aug 28, 2009 | HP Pavilion dv6000z Notebook
In device manager Network Adaptor has yellow exclamation mark. "Windows cannot load the driver required for this device." My HP Pavillion laptop is under guarantee - was purchased Feb.2008.
Completely remove the LAN adapter and disable "Plug 'n Play OS" in the BIOS, as follows:
1) Remove the card from Device Manager, under Network Adapter
2) Delete C:\WINDOWS\INF\DRVDATA.BIN
3) Delete C:\WINDOWS\INF\DRVIDX.BIN
4) Delete the following files. Not all of them may exist.
  • C:\WINDOWS\INF\NET82557.INF
  • C:\WINDPWS\INF\NET559A9X.INF
  • C:\WINDOWS\INF\NET5579X.INF
5) Shutdown and restart the PC, and enter BIOS setup.
6) Find the option for Plug and Play BIOS, and disable it.**
7) Restart Microsoft Windows* 95 and use the Intel® installation diskette to reinstall the adapter.
Dec 14, 2008 | Computers & Internet
General Networking question
lets see here, your NVIDIA thing is for your ethernet port in your computer.
the wireless PCI adapter, is well, a wireless adapter, its used to connect your wireless, and a 1394 Net Adaptor Connection is basically Win2k/XP's way of telling you that you have a Firewire interface installed in your system.
so, if your going wireless, you dont need NVIDIA, and as your device manager shows that it has a red x on it, it shows that its disabled. as for everything else, i wouldent worry about it.
May 08, 2008 | Computers & Internet
Microsoft tun miniport adapter #2 issue
did u ever tried to connect mobile to ur laptop.?..ur laptop has bluetooth.? just right click on the yellow marked adapter and uninstall that..try to do it again from the acer driver cd which is came with ur laptop...thats all
Dec 22, 2007 | Acer Aspire 5580 Notebook
Acer Aspire 5735 Notebook Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
