Question about Toshiba e-Studio 161 Copier Copier
Change Developer indication doesn't go of even after replacing the Developer?
  • 52 Answers
After replaceing the developer you have to clear the counter by going into service mode for techs and clear the total count for the developer to do this you need the service manual.
Posted on Jan 04, 2008
My Sharp copier cannot get out standby mode and is flashing the developer indicator.
install the developer unit , or change developer inside the unit,
and reset using Sim code 42-01
Feb 22, 2015 | Sharp Ar 5316
The machine i have is KONICA MINOLTA DI251OF.The light for the drum unit is on even after the drum been change.How can i get the light to turnoff
Was the developer also changed? Because who ever change the drum did it wrong. The first thing you do before you remove the old drum is cleared the drum counter, seems that was not done now the copier thinks the new drum is old and is applying the required voltages for a old drum even though the drum is new will have image problems and codes soon. Recommend you get a new drum, cleaning blade, and developer and replace them all their are normally done at the same time, because in a few week the developer will the go and so drum unit will show up a again. make sure you clear the counters first then install the parts and make sure you run the required F8 in service mode. Utility/Counter, Details then. stop00 stop01 for service mode. Under Function for F8 and counter for clearing developer drum image section which should be done after every forth drum the developer unit that hoses the drum and developer.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 20, 2011 | Minolta DiALTA DI2510F All-In-One Laser...
Am getting a functional errror on our gestetner dsc424 to replace developer units magenta and yellow. replaced both toners, but error message will not clear, even after turning off and then on again. can...
Hello!
Did you mean what you are saying?
If the machine are telling you to change the DEVELOPER UNIT why did you change the toner and hoped to reset the massage?????????????
If the machine are telling you to change the developer unit you need to change the developer unit!!!!!
Do that and your problem is solved
Sep 09, 2011 | Gestetner DSc424 Color Copier
I have an image runner 3220. The copies comes out with the black print looking faded and brownish. Can adjustments be made? If so, how? Or developer changed? How again? Thanks, Paul
How many copies do You have? ( press 123 button )
If You have over 150 000 copies, probably you need to change the Bk developer unit. It can't be changed only the developer, but the whole unit.
This is quite expensive copier for maintenance. If the time comes for Bk developer unit it means that you will soon have to replace Y, C and M developer unit. Also when did you last time replaced the drum unit?
Be sure to post back the copy counter, for detailed instrunctions...
Regarding color adjustment, before that you need to clean the copy optics ( glass beneath and cis sensor ), then in user mode ( asterix key ) under copy settings find color adjustment and perform it.
It's like 5 sheets, beeing printed one by one and which you need to scann over copy glass, but in most cases it doesn't helps...
If You want service manual you can write on emma.servis@gmail.com
Jul 29, 2011 | Canon imageRunner C3100N Copier
It's asking me to change the developer unit! What is this?
The developer unit is the part that is supposed to distribute the toner to the particular drum or photoconductor. a broken developer causes a faint or white line or even band in the concerned color. This is usually a difficult part to replace and the job is mostly very dirty. i advise contacting a technician.
Sep 27, 2010 | Sharp MX-2300N Color Copier
Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Feb 04, 2009 | Sharp MX-2700N Color Copier
How do i set aficio 1035 to factory default
SC352 Indicates ID Sensor/Pattern edge detect Error 3. If its a color machine, then it's a Magenta TD ensor failure.
Usually If you need to change the developer roller you should change the developer as well. Once that is done, then you go into service mode and calibrate the developer and initialize the TD sensor.
Did you change the developer?
Aug 02, 2008 | Ricoh Aficio 1035 Copier
Sharp copier sf 2530
Reset the developer by pressing C-CA-0-C - 83-5
May 16, 2008 | Office Equipment & Supplies
SF1118
You need to clear the developer counter. Simulation 24-6.
Jan 25, 2008 | Sharp AR-207 Copier
Toshiba e-Studio 161 Copier Copier Logo
138 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
