Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
The water flush goes on every 15 minutes it does not wait for someone to have a shower which it is connected to it or for someone to use the toilet what can we do to adjust it and stop the constant noise of it flushing. Is there an expert who can come and fix it in my area of folkestone kent. it is a one and a half years old and is meant to flush with the shower.
  • 302 Answers
I have a Richmond RCN 0595A12328, MODEL 5V40-7 40 gallon water heater. Can you tell me if there is some kind of an assy. I can use on it so when a toilet if flushed someone in the shower does not get...
The water heater has nothing to do with it. You need a shower control valve that won't let the water pressure change when the toilet is flushed. Moen makes just such a valve called a pressure balancing valve. Moen L82683 Positemp Tub/Shower Valve. http://www.moen.com
Jan 07, 2015 | Water Water Heaters
Help me locate a leak in the bathroom
need to check connections going to shower. turn on water and see if runs down lines. also try to reach up to the sink connections a do the same. they tend to come loose. should be able to hand tighten. also check behind toilet at connection.
Oct 08, 2014 | Jayco 2011 Greyhawk 31 SS
Vanquish shower goes hot and cold sometimes
Are the pressure ballance taps? If the shower is on and someone flushes the toilet the water will get hot in the shower,if they are not pressure ballance taps,or if they are the cartridge needs to be replaced in the tap.
Apr 18, 2013 | Home
When flushingtoilet water backs up inshower
You can try this, get a bottle of liquid plumber industrial or pro, and pour the entire bottle into the pipe in the toilet, when you remove the toilet cover you see a pipe that has a water line in it from the fill valve, if you can't pour the liquid into this pipe, then turn off the water to the toilet, flush it and hold the handle until all the water has emptied out.
Now while holding the handle, pour the bottle into the hole where the stopper is open, the hole where the water goes down.
Wait a hour, then take a bucket of hot water and fill the toilet water tank, flush it, do this again.
Now turn the water back on and flush. If the shower still over flows, you will need a plumber to come and snake the main line from the toilet down until the clog is cleared.
Unless he finds a close access near the toilet if this is on the first floor and he can do it from the basement.
Apr 13, 2013 | Motorcycles
Sewage backs into the shower when the toilet is flushed
Obviously the drain line from your toilet to main drain out of the house ( used by upstairs ) has a blockage from your toilet line to "Y" in to main drain line. Depending on how it has been plumbed, there may be a clean-out between the 2 that can be used to remove the blockage. Your drain for shower is piped in to same line as toilet, thus when blocked at other end, overflows to shower. You can try some drain cleaner down shower drain if it will go. You might get lucky and release the blockage before plumber shows up .
Sep 16, 2012 | Home
Every 15 minutes toilet float makes noise as if going to flush then goes away and makes noise every 15 minutes for about 10 seconds as if it is going to flush but does not and returns to silence but does...
The toilet flapper valve is slowly leaking. When the water level drops sufficiently this opens the fill valve to bring the level back up. This is all controlled by the ball float. A simple solution is to buy a new toilet flapper valve for your brand of toilet.
Watch this video for clues on how to clean and replace:
Dec 11, 2010 | Computers & Internet
It starts up before I flush!
is your saniplus connected to a shower or hand basin. if so - some water could be getting into the saniplus while you are on it and causing the unit to operate while you are "on the bowl". dripping taps / valves or a "leaky" toilet cistern are the most likely sources.
Dec 04, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
My macerator turns off and stops working for 10 - 15 minutes
the macerator is over heating.check the maintenance opening and clean it ,but you may need a more powerful macerator,some are made only for flushing systems (as in toilets) a pro-longed use may be making it overheat.. good luck
Jul 02, 2009 | Saniflo & Saniplus& Macerator Pump
Saniplus motor (flushing noise) keeps repeating
I believe you have a problem with a leak. The pump is filling back up. See is the water is leaking out somewhere. Hopefully, you don't have a leak under the house. The water coming into the pump is going somewhere when it comes on.
Jan 28, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
SHOWER HOT WATER SCALDING
hi as you are probably aware ,when the toilet is flushed the water pressure to the shower is reduced so you get hot/scalding water unfortunatly there is NO easy solution you could put a needle valve in the supply to the toilet and with trial and error by turning the valve down reach a compromise between the time it takes to fill the flushing tank and the shower temp the only real solution is to feed the toilet and shower off independent supplies but in most houses this is impractical if not impossible silk090
Jan 08, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
343 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
