Question about Gestetner Office Equipment & Supplies
What does error code SC387 mean on a dsc332 colour copier the machine giving off very bad fumes also
  • 541 Answers
It means you have a calibration error in your yellow development. you probably need a new yellow dev unit or the clutch or gears that drive it are bad. it could be a bad motor also
Posted on Oct 11, 2009
What is Canon error code #085
#085 mean your fax was sending a colour document to a machine that cannot print in colour!
Jan 13, 2014 | Canon Office Equipment & Supplies
I have an error code- E00060-0007
Error code 60 means the changing roller is not being detected position it properly. check if it is not in a pool of toner if so clean the toner properly with dry clothe.
Error 007 means the fixing fume is not being detected because it is damage and needs to be replaced.
Jul 14, 2011 | Canon Image Runner 3320I Copier
We have been advised to only use 90gsm or higher quality paper in our Gestetner, is this necessary?
in our country we use 70g or 80 this paper good not bad some people work on 60g but it stacking on machine good luck
Jul 13, 2011 | Gestetner DSc332 Copier
KONICA MINOLTA C253 COLOUR MACHINE ERROR CODE C-D403 touch screen not working printout not coming our service engineer could not find the error
The c-d403 code indicates a checksum error. Try turning the copier off and on via the Main power switch either behind the copier or inside the front door of the copier. Checksum error along with no operation panel means something could be fried on the main board.
Feb 17, 2011 | Konica Minolta bizhub C250 All-In-One...
SC387 error code on Ricoh
SC387 Drum potential
error
Cause
· Uneven charge
· Worn drum
· Defective potential
sensor
Try the following
1. Clean the charge corona unit or replace the charge
corona wire and grid plate.
2. Reinstall the drum.
3. Replace the drum if necessary.
4. Replace the potential sensor.
Let me know if you need any more assistance
May 08, 2010 | Ricoh Aficio Colour 3006 Color Copier
C-2204 Error code on C-451
The error code C-2204 is a waste toner bottle code. Try replacing the waste toner bottle with a new one and then restart the machine.
Sep 18, 2008 | Office Equipment & Supplies
Facing Problem in Canon Colour laser copier 1120
your a, b and c side sensors are bad they are found next to each other in the transfer drum
Sep 12, 2008 | Canon CLC 1120 Color Copier
Canon IRC3100 colour copier machine error code
Canon iRC-3100 Color Copier is giving Error code E-000021-0001. can anybody help me?
Aug 01, 2008 | Office Equipment & Supplies
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Gestetner DSC332 SC393-02
Hello klwhite,
The answer to your question:
Savin.......3224/3828/2820
Ricoh......2232c/2238c/2228c
The error code means that there is a problem with the yellow dev unit. The manual says that "during warm up" the TD sensor saw .78 volts or less when it performed process control. We both know that this device may perform process control at times other than warm up. Sounds like the yellow dev unit is the problem as the sc393 means td sensor and the 02 means yellow developer unit. I truly hope I have helped you. Take care.........spinal......
Apr 25, 2008 | Gestetner DSc332 Copier
217 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
