Question about Casio Exilim EX-Z120 Digital Camera
Casio EX-Z120 Lens Stuck
The lens is stuck in the out position. The camera will not turn on only beeps and then shuts off again.
  • 5 more comments
  • Anonymous Dec 20, 2007
    lens is stuck in out position with lens cover partly open. camera only bleeps and nothing else happens.
  • Anonymous May 18, 2008
    lens is stuck out and we have changed batteries still nothing just beeps
  • pvtben121 May 18, 2008
  • Anonymous Jun 08, 2008
    same problem too, please help don't want to buy new camera
  • MCWOLF41 Jul 29, 2008
  • calblazer Aug 22, 2008
    Same problem!  Lens will not close.  Power button beeps and then shuts down.
  • plsnstd Aug 31, 2008
    ex-z120,lens is out,when power pushed a big whooshing sound and that's it,the same if i push the play or record button,if i push either one and while pressing the menu button lcd comes on with a flashing " VER 1.00 ", then i press power and many green flashes by view finder then lcd shuts off, i have never heard any beeps, is there a solution?
This happened to me too. I think it might have been dropped and the lens was then misaligned. I just kind of had to gently push it back into position and it works fine now !
Posted on Sep 09, 2008
I need help tooo!!!
though i dropped it!! someone plesee help!!!!
Posted on Mar 07, 2008
I have also same problem what should i do ???/ plz help ma e-mail is
Posted on Apr 19, 2008
I have the same problem. No one knows how to solve this?
Posted on Jan 26, 2008
Camera lens stuck
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Nov 30, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens is stuck in the open position and when i try and turn on the camera, it makes a clicking sound and displays a LENS ERROR message
lens is stuck inthe open position and displays a lens error message and when I try turn on camera ,it makes a clicking sound
Jul 06, 2009 | Casio Exilim EX-S600 Digital Camera
Lens stuck
The slide motor start malfunction, You have to replace complete lens block assembly.
Thanks for using fixya.
Jun 16, 2009 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Casio exilim ex-z40 camera lens will not close and on/off button
Try blow compressed air around the lens, this might help if something stuck in the lens causing it not to retract. you can also try other suggestions from the link below. it's not for the same camera but it might help.
Mar 23, 2009 | Casio Exilim EX-Z40 Digital Camera
Camera beeps and shuts off
sorry to hear you are having this issue. well the problem is your lens. the len motors have locked up and are stuck the lens needs replacement. repair run any where from 75.00 and up in most cases.i repair these all of the time.let me know if i can help out any further.
Nov 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens Error
Hey Joy_2008,
A lens error usually means something is obstructing the movement of the lens (i.e. sand). You could try blowing compressed air into the side of the lens to try and dislodge whatever is stuck in the lens. You could also try placing the camera on a flat surface with the lens pointed up. While holding the shutter button in turn on the camera. What this sometimes does is force the lens to move before the camera shuts down, and when the lens moves hopefully it will dislodge whatever is stuck. If none of this works I would have the camera looked at by an authorized service technician. I hope this helps!
Go Ahead. Use Us.
Jul 30, 2008 | Casio Exilim EX-Z77 Digital Camera
Lens was stuck. And camera won't turn on.
Nope. That is a definate lens error. That is going to have to be sent into repairs.
May 25, 2008 | Casio Exilim EX-Z55 Digital Camera
Casio ex-z500 jammed with lense stuck in out position; gears grinding when power applied
I have just experienced the same problem with the lens jamming. I bought it for my wife having been impressed with the EX-Z500 my daughter bought. She had the same problem last year and paid for an expensive repair, then I found that her partner's sister had also bought one've guessed it...the lens jammed on that one too.
So that's another three Casio EX-Z500 digital cameras to add to your list of Casio generic lens jamming problems.
Apr 07, 2008 | Casio Cameras
Lens cover
I know this is an old post, but for those who want to fix it themselves: try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
Jan 16, 2007 | Casio Exilim EX-Z120 Digital Camera
Casio Exilim EX-Z120 Digital Camera Logo
303 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
