Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
Wrt54gl acess point,Hi can u help me about some technical problem my acess point are stoped when is been storm, he dosen dedicated a wan enter some idea??
    President:
  • 547 Answers
Try the instructions at this Tips page to reset the router to factory defaults. Once that's done, you should be able to connect to it on the wired LAN by pointing a browser to http://192.16.1.245/
I've also written a tips page about the default address, username and password for this access point.
Posted on Sep 29, 2009
Running BGP on WS-C3750X-24T-S using IP Services IOS?
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/release/notes/OL25302.html
Apr 29, 2015 | Cisco Catalyst 3750X-24T-S Layer 3 Switch...
Having problems with wireless connection to printer. Should I reset router, if so how?
Hi Are you using Windows?
Did you manually create the connections to the printer or use supplied software?
Do you have admin access to the router?
If the router has been configured correctly, just switch it off wait 10 secs then switch it back on to reset it.
Nov 15, 2014 | Cisco Linksys WirelessG WRT54GL Broadband...
My WAN port does not appear to work. (Data does not pass through it.)
Unplug the power to your modem and router boot the router up after 30 seconds wait for all the lights to turn on then boot up the router
Mar 02, 2014 | Linksys Wireless-G WRT54GL Router
Hi can you help me to unlock my blackberry 9530
It is so simple to Unlock your BlackBerry Storm 9530. go this site order your BlackBerry Imei Unlock Code and get your imei unlock code.
this site is offer best price.and guide you to how to enter your BlackBerry Imei Unlock Code.
customer support is excellent. i hope this site will help you alot.
Jul 31, 2011 | RIM BlackBerry Storm 9530 Smartphone
I cant acess my conflict desert storm game which i have installed it shows disc not entered
For gamecube? What do you mean installed, you shouldn't have to install anything on a gamecube.
Mar 25, 2011 | Gotham Games Conflict Desert Storm II for...
The router shows it is connected, but I do not have internet acess
Hello;
First connect via Ethernet. Then
  • Click START'RUN and then type CMD
  • At the black window with the prompt(cursor) type ipconfig and search "default gateway"
  • Type the gateway address in the browser ej: 192.168.0.1
This is for enter the web administration of the router. I don't know your revision. But I will get you the Hardware Version: A1 Firmware Version: 1.04
  • Aim for Status as the picture above
On the WAN section is the actual Internet. WAN = Wide Area Network. Your computer is actually on the LAN = Local Area Network. The Computer looks the address on the router, then the router go to the WAN for the information. But this is transparent to the user. If the WAN is in cero on the addresses, you have to check the installation. when the installation are correct power cycle the modem and the router and try again. Always connected via Ethernet cable. Hope to help! coquibiz.jpg
Nov 26, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Internet connection
Connect a computer to one of the lan ports 1-4.
Connect the adsl modem to "internet" or "wan" port of hub.
Open the hub's configuration page in your browser, usually this is http://192.168.1.1 Under Setup->Basic Setup, set the configuration for "Internet Connection Type " to "Automatic Configuration - DHCP". Under Network Setup, enable the hub's internal DHCP server so your lan hosts can get their ip's from the hub. Each local computer should have DHCP enabled. Your adsl modem must support DHCP for this to work, some do not. If it still doesnt work, try setting "PPPoE" instead of DHCP.
May 14, 2008 | Linksys Wireless-G WRT54GL Router
WAN light off on router
Hi Bootstrap,
Try a new cable. I know it sound strange, but I have had some work in one port, and not others.
If you still don't get a WAN link light, try resetting your router. We don't know what Netgear you have, but usually there is just a small hole where you press in with a paperclip, or pencil, and hold it in for 30 sec. Lights should flash when you release it. Connect your PC to one of the LAN ports, with the router powered up, and power up your PC. On your PC, go to STARTt>RUN>type in CMD. Press Enter. In the black bix that opens, type ICONIFG.
Look for your IP Address. It should be 192.168.x.xxx. (X can be any number up to 254.) Subnet should be 255.255.255.0. Gateway IP should be 192.168.x.1.
If your IP address is 169.xxx.xxx.xxx, you are not connecting to your router, or your router is not issuing an IP, thru DHCP.
Make sure your router basic settings is setup for your Internet connection type, i.e. DSL or cable. If all that fails, can you return the router? Is it new? What model Netgear is it? The WAN port not working does make me think it may have been damaged by a power spike. Have you had any lightning storms lately, or power outages?
Let us know if any of that helps. Or give us more info and we can see what else we can find.
Jan 13, 2008 | NetGear WGR614 Router
WRT54GL
By 'flush' do you mean Flash? If so, a Flash gone bad usually cannot be undone.. the firmware may very well be toast, and you will probably be purchasing a new WiFi Router...
I might suggest you also purchase a UPS (Uninterruptible Power Supply). They are not expensive anymore, at least for a consumer grade one... about $30 should do it.. It will at least give you time to shut down in time.. JMHO...
DG
Dec 20, 2007 | Computers & Internet
The 21ooap acess point confoguration
I think that you trying implement NAT on this wireless access point , if you got /24 mean you can use 192.168.16.1 - 192.168.16.254 range.This kind of router do have few steps to go basically you have to provide WAN settings that your up link information, then your Broadcast information such as SSID,DHCP,WEP.WPA,etc.
Nov 19, 2007 | D-Link AirPlus Xtreme G DWL-2100AP...
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
155 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
