Question about Garden
Uneven cutting using a Husqvarna Z4217 - Garden
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    YouTube - Level Your Lawn Tractor's Deck this should work
2 Suggested Answers
  • 3 Answers
SOURCE: i have husqvarna z4217 right wheel stops working when gets hot
check wheel bearing and replace.
Posted on Jul 23, 2012
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
I have a Husqvarna Z4217 was cutting and blades started making a rattling noise so I cut it off checking the blades the one on the right is loose but when I try to tighten it the pulley turns the blade...
You can use a block of wood and I even locked mine with a pair of vice grips or if there is room a pipe wrench. It would help to take it completely off and squirt some oil on the threads and start over then when you sharpen the blades they will be easy to take off later. I would sharpen the blades before you do this as well.
Mar 17, 2015 | Husqvarna Garden
Excessive vibrating
Exsessive vibration is normally attributable to the mower deck. If the vibration is occurring while the blades are engaged and cutting this would indicate a need for further investigation. Check the blades for damage or uneven ware. If the blades are new or appear in good shape check the mandrals and shafts to ensure they are not Brocken or bent. You can get mandrel assembly's for around $60.00 online and replace all you need in one go.
Jun 14, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
I have a problem leveling my mower deck. I level it at the sides and front .I use the mower and it cuts uneven. mower is deck is out of alignment. less than 1 hour on it.
The deck could be bent, or you will probably have to level the back of the deck as well. Another thing to check is the air in the tires, this can cause an uneven cut. Although the tire may look pumped up, with the weight of a person on the tractor can cause an uneven cut.
Aug 10, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How to change oil on Residential Z4217 zero turn mower
On the left side of the engine, (looking at it from behind) their is a yellow cap, 1. pop it off, 2. turn tube to left, 3. pull tube out.
Oil runs out and back down the indention and out through the hole at the rear. it can get messy. I enlarged the hold at the rear for quicker draining and less mess.
May 29, 2010 | Husqvarna Iz5223 Zero Turn Commerical Lawn...
Engine will not turn over
Those boxes are probably relays. Sounds as tho one of your safety switches is not working correctly. Make sure you have the machines brake on, blade off, and any other safety measures are applied, such as the operator is sitting in the seat. Check the wiring connections at all the connections where the safety features are installed. Probably just a connection that is not letting the system know that all systems are indeed applied.
Nov 14, 2009 | Husqvarna Zero Turn Mower Z5426
I have a husqvarna 350 chainsaw, it wont cut straight throuh a log without cutting at an angle and getting jamed. what is the problem , any sharpening tips
THE ONLY THING THAT CAUSES A SAW TO CUT ON A CURVE IS THE CHAIN IS SHARPER ON ONE SIDE THEN THE OTHER AND IT PULLS THE SAW CHAIN TO ONE SIDE CAUSING THIS PROBLEM.
THERE IS NOTHING WRONG WITH THE SAW, IF YOU USE A FILE TRY A FILE GUIDE THEY WORK GREAT
Sep 17, 2009 | Husqvarna Garden
New blades,correct air pressure still cuts uneven
try pulling the mower on a level surface and checking the deck for level if that checks out see if there is any play in the blade spindles ( with the mower off of course) hope this helps
Jul 15, 2009 | Husqvarna Garden
Garden Logo
203 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
