Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
Poor sending and recieving
Very limited range of about less than a quarter of a mile
  • 126 Answers
In my experience, most of the time when you can't rx or tx more than 1/4 mile, the antenna is grounding out, the coax center conductor is broken, or the coax center condutor is shorting out to the sheilding.
Dean
Rollin CBs
Mt. Vernon, TX
Posted on Jan 23, 2008
    Novelist:
    Champion:
  • 211 Answers
Make real sure that you have a good SWR for your antenna system. ( No higher than 2;0 to 1 ). To do this it will require an swr meter. A meter can be purchased at any CB Shop that sell finer products. If the SWR's are good, then you probably have a bad final or driver transistor in the Radio.
Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
The gas needle mostly goes up to a quarter or little less than a half tank when you fill up but not right away, sometimes it's about after you've ride 3-10 miles. The gauge will drop to the low level
therecould be a few things wromg simple fix, first check the float sounds like it has a hole in it take bolts out of bottom of tank an slide fuel pump an sending unit out there will be a arm that moves up an down on the end of thqt arm will be the float you can dip it in water to see if it floats or sinks replace if it sinks
Jul 28, 2013 | Motorcycles
I have a 2006 Pontiac Montana. My gas guage is extremely unreliable. I run out of gas when the guage shows a quarter tank. And the digital readout for fuel range will say I have anywhere from 65 to 130...
I would guess you will have to replace the sending unit in the tank. A mechanic can check the sending unit with a meter and find out if the sending unit is faulty or the gauge on the dash.
Jul 08, 2013 | Cars & Trucks
Motorola mj270r no range
Handheld radios talking line-of-sight with no obstacles will communicate approx. 2 miles. When talking from inside a building to outside, you can expect 1/4 to 1/2 miles range. Holding the antenna perpendicular to the ground gives you the best range. Height and placement of the antenna determines range. If you were on a mountain you could talk many miles into the valley below. However, in real world applications, range is limited. It can even be limited by the body fluid of the person wearing the radio on their hip, or blocked somewhat by the metal of the automobile one is riding in.
Channels 18-22 are listed as GMRS channels and may have more power than 1-17. The FRS channels are limited to 1/2 watt. But don't be fooled wattage doesn't equal distance. Higher wattage may give you a little more distance, but mostly it will give you clarity in the fringe areas.
Here is a link to the user guide: http://www.motorola.com/web/Business/Products/ConsumerTwo-WayRadios/Talkabout-MJ270R-Two-Way-Radio/_Documents/MJ270.pdf
A link to Motorola's page about the radio: http://www.motorola.com/Business/US-EN/Business+Product+and+Services/Two-Way+Radios+-+Consumers/MJ270R_Talkabout_Two-Way-Radio_B2B_US-EN
And I see where they are quoting 27 miles*, and go on to say:
*How far can I expect my radios to communicate? The communication range quoted is calculated under optimum conditions, with an unobstructed line of sight. Actual range will vary depending on terrain and conditions, and is often less than the maximum possible. Your actual range will be limited by several factors including, but not limited to, terrain, weather conditions, electromagnetic interference and obstructions.
Unfortunately, we are seldom in idea conditions. Radio-to-radio is going to get you 1/4 mile to 2 miles in real conditions.
Best regards.
Feb 24, 2013 | Motorola MJ270R Talkabout 2-Way Radios...
2008 jeep grand cherokee stalls while driving 4.7 v8
The 2001 Grand Cherokee limited 4.7 does the quarter mile in 15.563 seconds. The 2008 v6 Mustang does the quarter mile in 15.378 seconds. It is possible but unlikely. ----------------------------------------------------------------------------------
lexia 3 pp2000
Dec 24, 2012 | 2008 Jeep Cherokee Grand
2008 grand cherokee stalls while driving 4.7 v8
FGTech Galletto 2-Master EOBD2 V51 BDM-TriCore-OBD
Dec 24, 2012 | Jeep Cars & Trucks
I am just wondering if its posible to extend the range of the simon alarm panel? I have connected the internal ariel to another cable to extend the range, this worked but not to the level i require. Is...
No.Not possible this thing only work for a quarter of a mile ok for the best operation.It is preset for the range for it best functions,u manage to extented for a littte further.No,the range will not go further beyond a quarter of a mile,if u plan to go beyond that.
Nov 13, 2010 | GE Security Simon 3 Wireless Home Security...
I can receive well, but have limited output..can receive from drivers over 10 miles, but when I try to talk back I only have about a 1 1/2 mile range I got a new power mic, but it doesnt seem to help......
Could be poor antenna, or not high enough on the vehicle.
Also most truckers have had their radio's peaked and tuned.
If this radio is stock its only putting out 4 watts, which should still get you about 8 miles.
I do not know what the modulation and AM power POT's on the board of this radio are.
You can take it to a truck stop that has a radio shop. they can peak it usually for less then $30
Oct 20, 2009 | Magnum S9 Base CB Radio
Motorola z3 , cant recieve picture messages
any photo you take with your phone can be sent, the 1600x1200 pixel photos are the largest this phone will take which is a 2.0 megapixel photo, when you send these, your internet provider will require them to be a certain size, for instance tmobile will require that the photos are 640x480, so your phone will resize them, before they are sent via mms. If you send them by bluetooth directly to someone in range they will be the full 1600x1200 pixel size or what ever size you take. Recieved photos must be this size or less and JPG format for them to be viewable on your phone... if they are larger they will not be recieved , this is normal. due to size constraints.. let me know if you need any further help... :-)
Dec 09, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Cobra 132 recieves good poor send
i would take it in and get a new diamond thats what it sounds like to me..
Dec 02, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
T 5000 (Talkabout Hand held Radios)
Hi Mark,
I understand your concern with the actual range of the Motorola T5000. Being UHF radios, they are severely limited by any obstruction in between, be it trees, buildings, hills, foliage, terrain and any others that would block "line of sight". Additionally due to the inherent design restrictions imposed on these radios, the FRS channels are limited to pushing out 0.5 watts making the GMRS channels better choice since the radio will be transmitting at 1 watt. To my knowledge, channels 8 - 14 are FRS only.
Possible things you can try to improve transmit distance are:
1. use AA Alkaline batteries instead of the rechargeable ones;
2. disable or minimize settings of interference eliminators, Quiet Talk, noise filters, coded squelch or CTCSS;
3. replace the stub antenna with a Larsen Quarter wave. You may need to install a BNC mount to accommodate the Larsen. Incidentally, this will also improve the receive range and not only the transmit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 19, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
118 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
