Question about Lexmark X5150 All-In-One InkJet Printer
Black ink fading in print jobs
I am printing lables. The first 3 rows printed fine,nice black color. The next 5 rows faded to grey. The 6th row-fine, black again.
Newer ink cartridge which shows half full on the printer display.
Test page showed black ink is only printing solid on the right hand side of the test bar. Thin grey lines across rest of test bar.
Printed a plain doc file just fine 30 minutes ago.
Any ideas?
4 Suggested Answers
JMuskovitz
  • 135 Answers
SOURCE: printing black squares in word.doc
It sounds like this is an HP driver issue. HP drivers have built-in "optimizations" (that unfortunately have bugs) for things like printing photos. Different programs (word, for example) try to take advantage of these optimizations in different ways. When they work, they give superior photo printing (faster, with more accurate color). When they don't, you get black squares. This is why "converting" it to PDF worked for you -- Word printed it through the PDF driver instead of the HP printer driver, then when you printed the PDF file, that program avoided those optimizations when it sent the images to the printer. Unfortunately, the translation caused quality loss. If your goal was to print out something like a "proof-sheet" of photos, you might try the free photo organizer at www.preclick.com. It will print these for you, captions and everything, and should be able to avoid the driver issues.
Posted on Apr 11, 2007
Garfunkel01
  • 56 Answers
SOURCE: Lexmark X75 no color
even though you have ink coming out of the cartridge, if it's more than a few months since it's pumped any ink, it can be clogged internally, blotting with paper doesnt always work. Try a new cartridge, or buy a new printer, it's usually cheaper now to get a whole new printer than it is to replace a set of cartridges. consider it's a few years old now
Posted on Aug 16, 2007
xptareq2000
  • 1447 Answers
SOURCE: Our lexmark Z705 printer only prints won't print black.
Clean your printer cartridge printer maintainence program or alignment or head clean
Posted on Jun 28, 2009
Faded print on dell c1765nfw
Hate to sound obvious but have you tried replacing the ink cartridge?
Oct 15, 2014 | Dell Multifunction Color Printer C1765nf...
How do you fix the colour printing grey instead of black
Do you need to change out your black color cartridge? Check your ink levels to make sure that you have plenty of each color. Also, check the settings for your printer (perhaps under "properties") and make sure that you haven't clicked on "grey scale". I hope that this helps.
Jul 15, 2014 | Xerox Phaser 7400/N Printer
Deskjet 1050A is not printing black. Help?
The black ink cartridge is cloged or empty. Try to refill it in case of empty, or clean in case of cloged ( left the printhead for 1 hour in clean solution or in hot water if you don't have )
All the best !
Jan 18, 2018 | HP Office Equipment & Supplies
My printer has been printing for 3 days in a row now WITHOUT a black ink cartridge inserted! How is this possible? It prints black text alright, so it cannot be the color cartridge in there doing the...
If there is no black cartridge installed and the printer is printing "black", it's not true black. The printer combines the colors to make black. I didn't think that it would print at all with a cartridge missing. Learn something everyday!
Sep 17, 2010 | HP LaserJet 3050 All-In-One Printer
My HP 3550 won't print black when it is out of a color.
restore the properties.... set as "print in grey scale" or "print color as b/w images"...
also if the print become less or more dark you can change the settings to print whit more intensity or less...
there is no necesary change all your documents as "watter ink" only change the print options to fade to black
May 15, 2010 | HP Color Laserjet 3550 Printer
Print keeps fading, even though using new ink
check your printer settings, make sure color only is not checked off, or if you mainly print black and white documents, you should have that option checked, you may have to go into advance printer options to do this.
Apr 07, 2010 | HP Deskjet 3845 InkJet Printer
I have a ip4200 and when printing in black it is faded and stripe
The print head is clogged.Make sure black ink cartridge have ink and then try unclogging with cleaning tests in maintenance mode.If not help try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If
this not help you need to replace the print head.
Nov 20, 2009 | Canon Office Equipment & Supplies
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Standard black printing has faded to grey.
Could just be a faulty cartridge?
My hp printer developed a similar fault, and despite all my attempts to clean, realign, whatever, the problem wasn't solved till I fitted a new ink cartridge. It's worth a try.
Nov 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Lexmark X5150 All-In-One InkJet Printer Logo
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
