Question about Dell Precision Workstation 670 PC Desktop
I have a dell precision 670 that beeps on start up and then I get no video. In some case if I were to pull the plug, walk away and then come back in a few mintues to do a startup I can get it all back but if I do a restart from the start icon in the lower left corner there is no hope. Anyone know what's going on?
  • wizbit May 11, 2010
    Is the video connector on the system board or does your PC have a Video card fitted?
  • 3,153 Answers
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Sep 23, 2009
What causes a Dell Precision one beep then shuts down?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Bios beep codes to many popular systems are given.
Aug 08, 2014 | Dell Precision Workstation 670 PC Desktop
What windows 7 ultimate drivers do i need for it to work with pecision workstation 670
You will need audio driver, possibly Network adapter driver and in some cases you may need to find the manufacturer of your optical drive by pulling out of the case to get model type and then the the driver from the manufacturer's site. Finally a chipset driver. check this site for most of the drivers.
http://www.dell.com/support/drivers/us/en/19/product/precision-670
Apr 23, 2014 | Dell Precision Workstation 670 PC Desktop
Precision 670 crash during bios upgrade from dell site, now when i start the computer it beeps and nothing happens. I need solutions! Thanks, Pablo
How many beeps? Any pattern? (e.g., short, short, long, long, low, high) ?
Contact Dell, and purchase a replacement motherboard.
Sep 02, 2010 | Dell Precision Workstation 670 PC Desktop
DELL Precision Workstation 670 second processor not working
Did you change BIOS settings or does your BIOS supports dual processors?
Jul 19, 2010 | Dell 3.8 GHz Second Processor for...
Dell Precision 670 6 long beeps on post no video but pc is on
Please consult this Dell link for general startup troubleshooting for your system., and this link will take you to the codes for the error lights and beeps.
Finally, here's a good article to help solve general startup problems and diagnose the possible cause.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 26, 2009 | Dell Precision Workstation 670 PC Desktop
Try different memory modules ( RAM ) and see if it is just the RAM.
Also take anything else out you dont need - including dedicated graphics card assuming it has onboard graphics card ( if so then enable the onboard graphics card before taking out the dedicated one )
If its still the same then yes it is the motherboard in which case you need the motherboard replacing.
If you did the diagnostics that they walk you through and they still tell you its the motherboard then it will be the motherboard as there diagnostic software is accurate.
May 06, 2009 | Dell Precision Workstation 670 PC Desktop
The 3 beeps is an indicator of, most likely, a memory fault. This could be caused by incorrect memory configuration (unsupported RAM type or speed), not fully seated RAM, or the RAM itself has been damaged in some way. Best advice I can give to you is to open your case and verify that all Memory Modules are fully seated and locked into position. If they are, next step would be to remove all but 1 chip, and try turning it on. If it turns on, then one that you removed is the culprit, if not, that particular module may be the culprit and change it for another. If, after all memory modules tried has not allowed the computer to start, I would recommend taking it to a service center to be checked, as they would be able to verify the MB has not gone bad with using a module they know to be good.
Hope this helps!
-Backu
Jan 15, 2008 | Dell Precision Workstation 670 PC Desktop
Dell Precision Workstation 670 has no video on screen.
Support for ISV-certified PCI Express graphics cards up to 150 watts and with up to 512MB graphics memory including: nVIDIA® Quadro® FX 4500;
nVIDIA Quadro FX 3450; Quadro FX 1400; ATI™ FireGL™ V3100; nVIDIA Quadro NVS 280; All graphics cards support dual monitor configurations
Although it may not be your video card thats the problem. when youre computers posts, it beeps once. If it is beeping more then once youll want to check with the board manufacturer to see what the code its giving means.
Dell Precision Workstation 670 PC Desktop Logo
495 people viewed this question
Alun Cox
