Question about Sony Handycam CCD-TRV11 8mm Analog Camcorder
AC-V16A ADAPTER DOES NOT CHARGE AND SHOWS A RED LIGHT. CAMCODER WORKS FINE FROM IT
Your'e Battery is damaged, thats all.
Gr Diver
Posted on Feb 16, 2008
Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Oct 25, 2012 | Computers & Internet
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
Battery light is blinking red and will not charge
Welcome to Fixya! If the battery light is blinking red,that indicates low power, there's a possibility that the problem is with the AC adapter, or the battery or maybe the DC port itself, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Feb 28, 2011 | Panasonic Toughbook CF-73 Notebook
Not charging
which green light?
light from the ac power adapter or the light from the battery?
if ac power adapter you are referring to try a diff power wall socket if ac power adapter still off then replace ac power adapter alone.
if battery light is off but the laptop works fine with ac adapter alone try updating the laptop BIOS.
if ac adapter light turns off when it plug to the laptop replace motherboard.
Oct 13, 2009 | Dell Latitude D531 PC Notebook
Will not run on ac adapt. only battery and will not charge
Check by connecting the adapter to another plug point.
Please check the light on the AC adapter. If there is no light then it is better to replace the AC adapter.
Check the laptop with another AC adapter of the same type. if the laptop works fine with the other AC adapter then replace the adapter
If the light on the AC adapter is on visit the manufacturer's website and try to update the BIOS. If this does not work. check by juggling the connector at the laptop's end. If the laptop charges intermittently or if there is no signs of charging, it is advisable to contact the manufacturer for having the motherboard checked.
Jul 13, 2009 | Dell Latitude D510 Notebook
Laptop battery not charging wanna know how to run without battery
The problem you described here shows that, the case is not likely to be a battery problem, but the laptop AC-Adapter (Charger) problem, because, the red light you are seeing shows that your battery has rundown, and even when you plug-in the adapter to AC, it still blinks red, showing that the AC-Power is not charging it. I would suggest that you get another Laptop AC-Adapter (The Charger), or try it with a friend's own first, then you'll see that the problem might not be with your battery but your AC-Adapter
Jul 09, 2009 | ASUS Computers & Internet
Canon DC20
This happens alot at work its either the charging part is broke or its the mainboard inspect the port for damage if its ok then inspect the ac adapter for damage as well, if you have time you could go to best buy and ask to use a charger from a floor model if it doesnt work then it needs to go in for repair sorry.
Dec 21, 2007 | Canon DC20 DVD Camcorder
R40 2724-BU1 Power Problem
Check the ac adapter. It seems your adapter is not charging it. Either the ac adapter or your dc port may be the problem. Is this the correct adapter, is it giving the correct voltage. These should be considered also.
Hope this helps you
Oct 20, 2007 | IBM ThinkPad R40 2722 Notebook
Sony Handycam CCD-TRV11 8mm Analog Camcorder Logo
240 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
