Question about Car Audio & Video
Wont hold the radio stations once the unit has been turned off.
    Brigadier General:
  • 4,044 Answers
Double check the wiring to make sure the secondary power source is a direct connect to a wire that is hot even when the vehicle is turned off and check for a blown in-line fuse.
Posted on Sep 23, 2009
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
Tip
How to use your iPod as a radio.
Connect the iPod Radio Remote to your iPod Nano by plugging it into the dock connector. Plug your headphones into the port at the top of the Radio Remote, next to the hold switch.
Once the Radio Remote is connected, select "Music" and then "Radio" on your iPod. The Radio Remote will automatically tune in to the first available station it finds. The iPod screen will show the radio station and any other available information or data.
Press the center button on the iPod. Use your iPod click wheel to find other stations. Once you have found your favorite station, hold the "Center" button down until a triangle appears on the radio dialer on your iPod screen.
Step4 Once you have set up all of your favorite radio stations, use the "Next/Fast-Forward" or "Previous/Rewind" buttons to navigate between them.
on Feb 11, 2010 | Computers & Internet
Radio wont set stations
hi, does the radio go back the standard settings when you turn off the key, if it does than try checking the fuse for the constant power supply as this controls the time memery and the settings for the stations, if not try holding the station button down for 3 to 4 sec
hope this helped
Jun 13, 2013 | 2001 Chrysler Sebring
Radio stations wont store once key is taken out
if the unit only looses radio station presets then there is a defect with the unit. if the unit looses all its memory, (clock, stations, settings) then there is an issues with your aux power. basically you have the main power connect properly so it turns on the unit while the cars is on but the aux power keeps those settings.
Mar 08, 2011 | Virtual Reality VRCD500-SDU CD Player
Radio
Feb 11, 2010 | Apple iPod nano
How to lock in radio station on kenwood face off cd player
once you have the station you want to listen to on the radio press and hold one of the buttons along the bottom of the stereos face for a few seconds the screen should flash for a second or two or it should beep as well to indicate its saved it.
if when you turn the ignition off and then turn it back on the stereo has forgotten the station you programmed you need to remove the stereo from the car and check the wiring at the back of the unit. most of them have a red and yellow wire that are joined by metal push fit connectors, swap these two over and it will then remember the station for you.
the red wire is the switched power lead from the ignition and the yellow lead is a constant live feed for it to remember your settings, if these are round the wrong way it will keep forgetting radio stations you program until you switch them over.
hth
Dec 30, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Jensen UV9 wont hold preset stations
the memory wire will be the thick yellow wire that is your constant. you hook the yellow wire to the yellow wire on the radio and you should be good.
Jul 22, 2009 | Car Audio & Video
Y sony direct comparator st s444 es 2 does not hold radio stations. Once power has been turned off for more than a couple hours, memorized radio stations are lost. Thank you
You could try looking for a memory retention capacitor on the circuit board. It will be on the board with coils etc. They sometimes are marked on the board. However they look like squashed electrolytic caps. They have a value of between 0.022 and 0.047UF and a voltage of around 5.5 volts. If you see one like that and it's near an IC then you found the trouble, replacement should stop the loss.
May 15, 2009 | Audio Players & Recorders
Radio presets?
select radio station then select which number you want to preset station to and press and hold until you hear the unit beep,also preset station will flash once aswell as the beep,station should be preset into your headunit,goodluck.
Nov 29, 2008 | Pioneer Car Audio & Video
Sony car radio/CR/cassette doesn't hold pre recorded radio stations once ignition is turned off
run the yellow wire to the battery as its the memory wire and that will work if it is installed correctly and still does the same it can be the battery even if the battery still works.
May 25, 2008 | Car Audio & Video
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
