Question about Poulan Garden
Change the sproket
How to change the sproket
    President:
  • 2,220 Answers
R² Drive Link Inboard Clutch
http://www.youtube.com/watch?v=YUbSIHMSSP8&feature=PlayList&p=4A4A1DF66590854E&index=0&playnext=1
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
GL
Lou
Posted on Sep 23, 2009
Testimonial: "very helpfull"
Howdo i get the caseing off the front sproket 1992 750 nighthawk
Hi,I think you are talking about the front drive chain sproket casing.
well if this is what you meen,you just have to disconnect the linkidge for the gear lever undo the allan key screws and it should just pull off,hope this helped.
Apr 17, 2015 | Motorcycles
Tightening primary nut on 1999 fatboy
Hi Anonymous, If you are talking about the compensating sproket nut you need to jam a large soft piece of metal aluminum or brass or a piece of hard wood on the bottom of the primary chain and compensating sproket to keep the engine from rotating. Then torque the sproket nut to 165 ft lbs. Good luck
Apr 17, 2014 | 2000 Harley Davidson FLSTF Fat boy
Change out a neutral switch on a 2003 harley davidson xl1200c sportster
Hi Anonymous, the nuetral indicator switch is located behind the sproket cover. You need to remove the sproket cover, slide the rear axle forward and remove the front pulley to gain access to the switch. Have nice day.
Mar 24, 2012 | Harley Davidson XL 1200 C Sportster Custom...
Popping noise coming from front sprocket when wheel is turned on 01 suzuki gsxr 600
hi it sounds like your front sproket is really worn and hooked when you turn the chain its not releasing the links smoothly ,replace it with a new one and check the condition of your chain it may be worth replacing a complete chain and sproket set as running a bike with a worn front sproket could lead to a back wheel locking up at speed if the chain jams
Feb 22, 2011 | 2001 Suzuki GSX-R 600
How do i time a 2002 dogde neon?
you need to take apart all the front of the engine until you get to the timing belt,once you are there,you are going to look for the marks on the sprokets,in the crank shaft sproket is a dot,align it whit the triangle that you are going to see back housing,the cam shaft sprokets you are going to see the marks.on the right sproket it is going to be slightly half dent foward.
Sep 29, 2010 | 2002 Dodge Neon
Engine still cuts out and backfires after changing coverter
This seems to be a timing problem. backfiring usually means that the timing is off. The timing belt sproket could have worn off or belt its slipping.If your car has a timing chain that could have broken sprokets. Timing is usually the culprit here in cases like this.
Jan 21, 2009 | 1992 Chevrolet Lumina APV
Need to replace timing chain on 2005 cavalier
I'm doing this myself, and there are some annoyances. Yes, a service manual is good, however, I consulted 2 manuals and got two different answers. Here is the real deal for the 1996 2.2 vin 4 cavalier.
Remove the right tire and platic sheilds. Remove the tensioner pully, (2 bolts).
Remove the harmonic balencer on the crank shaft, 3 bolts first then the center.
Use a pull hammer with correct thread to pull off the "crankshaft thing" on the end of the crank shaft. Be sure to pull it off evenly. I had to find a bolt with the same threads, cut that off, and tap a fitting for my **** hammer. It's on there good.
Remove 7 (8mm) bolts from around the chain cover. Remove the 2 (10mm) bolts from under the cover. Those two studs also have to come out with a small inner tourqe socket. These are very very easy to strip, be careful. The cover is now free.
It is sealed on tight. There are a couple good places to get a bite on the rear facing edge. You will also have to work from the top and bottom to get it free. It pulls strait out, it is positioned by pins. Be patient, that cover will break.
There is silicon that seals the bottom of the cover. Clean that all off with a scraper and wire brush. Pull off and clean where the gasket seats all around the cover. Clean the cover. Replace the gasket and the outer oil seal that goes around the crank shaft. The only way to get that seal out is to break it. Press the new one in with a vice, do it evenly and slowly.
I've found a good method to get the cam shaft sproket off.... There are 3 slots and a hole. Rotate the cam sproket clockwise till you get the hole to about 9o'clock. Put drill bit or short piece of hard metal (something that won't bend) in that hole and apply some pressure while you rotate another 10 degrees or so. The bit will drop into a hole. Now rotate counter-clockwise and the bit will bind the sproket so you can remove the bolt. Nice huh? I get it unbound by putting a screwdriver between teeth and prying against the crank shaft. Use your imagination.
The timing **** is retarded. And I still havn't found a deffinate answer for everything. The crank shaft makes two rotations for every one that the cam makes. The first crank shaft rotation is the compression stroke, the second is the power stroke. I don't know how to tell the difference.
To get the sprokets aligned, re-install the cam sproket, don't worry about getting it tight. Rotate it clockwise until the hole in the sproket lines up with the ear on the chain tensioner. Now, bind the gear right in that spot and remove it. Now, take that "crankshaft thingy" and push it on by hand as far as you can. Notice the key, and dot on one of teeth. Put the bolts partially in the thingy and rotate it by using a bar or screwdriver between the bolts. Move that sproket until the dot on the tooth lines up with the ear on the chain adjustor. The key will point directly up. Good job. Tap that thingy off the shaft now.
Compress the chain adjustor and put a pin through it. With the cam sproket removed, put the chain on it. Work the chain onto the crankshaft sproket. Slide the cam sproket onto the camshaft. Easier said than done, but it is possible. If you are having a hell of time, use a mirror and check that you are lining it up properly with the pin/key in the crankshaft. I found that leaving a little slack at the top, as opposed to the bottom helps. FYI, when i say little, i mean it. There is very very little slack, but the chain does buckle slightly.
Remember me saying that I have no idea how to tell between power and compression stroke. Now you will hate me. To get mine right, I had to tighten the cam sproket then replace my spark plugs and attempt to start to start the car. I guessed mine right the first time and it ran fine. However, if it ran rough or not at all. I would have had to remove the cam sproket again, remove the chain and rotate the crankshaft sproket one full turn.
When you put this all back together, use plenty of slicon on the bottom of the chain cover. Re-assembly is a snap, or at least is was for me.
Jul 28, 2008 | 1998 Chevrolet Cavalier
Kitparts
Check the sproket on the camshaft for broken links and the gears on the crankshaft. if all this look good, then install the timing belt. If you do remove the camshaft sproket, make sure to mark it exactly where it is at compared to the mark on the engine. Do not turn the engine at all. Everything has to be aligned exactly.
Jul 15, 2008 | 1996 Honda Prelude
Timing
Have you checked your initial timing? Have you checked your fuel pressure at Idle? Have you changed your fuel filter? How was the idle before you changed the camshaft and lifters? What steps did you use to adjust hydraulic liters, did you turn them down 3/4 to 1 full turn after you set them? Maybe you have too large of a camshaft? Maybe you have a vacum leak?
Jun 23, 2008 | 1991 Chevrolet C1500
Garden Logo
64 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
