Question about Konica Minolta magicolor 2300DL Laser Printer
My magicolor 2300dl printer is showing waster toner box full and won't print but the waste toner box is empty and new. Is there a reset button on the printer to bypass this error?
1. Empty the waste box.
2. Read p66 of http://printer.konicaminolta.com/service/ASP/mc2300/documentation_manuals/mc2300SM.pdf
3. Identify the "Waste Toner Full Detecting Sensor" which tries to pass a light beam through the protruding plastic slot on the waste box that engages with the photocell.
4. Use a dry cloth to clean dust off the photocell transmitter and receiver and also off the protruding plastic slot, so that light will now pass through.
5. Refit the waste box and enjoy the $$ saving.
Posted on Oct 14, 2009
I've replaced the toner cartridge and waste toner bottle, but the display still says 'toner low' and 'waste toner near full'. It refuses to print, even with the old cartridges.
Then you mite want to clean the sensor that monitor the waster toner box pull out the waste toner box and look for the area that show clear plastic then look for those area of the machine and blow the old toner from those areas waste toner mite have gotten on the sensor saw they can not see the clear plastic and think that the waste toner cart is still full.
Sep 09, 2014 | Konica Minolta Magicolor 5670EN Color...
2300dl toner problems
Unfortunalely printers and there drivers estimate toner life buy counting the amount of dots draws on the pages. Say a cartridge is rated for 3000000 dots when new, the printer will know after printing 1500000 dots that the cartridge is about half full. If you replace a cartridge the printer will assume it's new as the ID tag will be different from the last cartridge. There really isn't any way of modifying or specifying the age of a cartridge. You will just have to keep using it until you start seeing drop outs on the page, then you will know it is almost empty. Shaking it a few times will usualy help stretch the life of a cartridge.
Jul 04, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta 2300DL waste box full message
remove the waste box you'll see blue knob and above there is a sensor now take a look at the waste box and find the place what goes between the sensor. you should cut off one side and clean the other sides and then use some invisible tape to fix the hole. and try again.
Place what goes between the sensor have to be clean. its not good idea to cut or remove the sensor at all because next time the box will be full you don't know that and it will brake your printer
Mar 22, 2008 | Konica Minolta magicolor 2300DL Laser...
Magicolor 7300 print window says Ink/toner waste bin full! but it's new
The clear section of the waste toner box where that goes inside the machine check that area sensor located there might have toner on it so the printer thinks the waste toner box is full
Apr 16, 2012 | Minolta magicolor 7300 Laser Printer
Can't make machine print Konica Minolta 2300DL
As soon as you open the door on the right side of the unit the waste collection box is there. You will see it, it is the large strangely shaped item that extends from the middle top to the bottom of the unit.
Jun 25, 2009 | Konica Minolta magicolor 2300DL Laser...
Where are the toner cartridges in magicolor 2300 dl
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Wast toner full
You need to replace the waste toner kit part number 1710522-001
Jun 10, 2008 | Konica Minolta magicolor 2300DL Laser...
My Magicolor 2300dl printer displays a 'Waste toner box full' message, even though I have just emptied the waste toner box.
. Remove Waste Box, Empty box, wipe down w/ dry paper towel
. Turn machine off,. Unplug power cord
. there is a blue rectangular pull knob
.above Rectangular knob @an angle R 2 notches (contain ensors)
. Take an AIR can & hold 6-8 inches & spray N2 ea. sensor
. this should clear any particles that generate a false " Full " Signal
. credit to Nightangel for getting the ball rolling. Thx
Feb 28, 2008 | Konica Minolta magicolor 2300DL Laser...
What is "FULL"? I fyou mean the drum, then you want the display to show that the drum is full - this is correct for when a drum has been changed.
Maybe you mean the toner bottle is full. If so, emptying it will resolve the issue.
Oct 09, 2007 | Konica Minolta magicolor 2300DL Laser...
Magicolor 2300dl
Clean the fuser, opc drum, and the basic inside of the printer with a vacumm. Suck don't blow with the vacuum.
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
386 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
