Question about Casio Parts Cash Register PC Desktop
Casio TE2200 with Cipher 1000 Barcode scanner still not working
I still cannot get the barcode scanner to work with the TE2200.
The barcode scanner is a Cipherlab model 1000, RS232. The scanner seems to be working perfectly by itself. I can program it easily, and test it with Hyperterminal no problem.
I've programmed all the keys OBR,NLU,Price Inq,Price Change, etc.
I've selected the EAN13 barcode
I've setup the 13 digit PLU correctly in the Casio, as I can type the number in manually and the Casio displays the correct information, price, etc.
I can connect the PC with the TE2200 and transfer files both ways on COM1 of the TE2200.
The barcode scanner is plugged into COM2 on the TE2200.
I have the baud rate on the scanner set at 9600, with 8 data bits, 1 stop bit, odd parity.
I've entered the PLU's correctly into the TE2200, and can recall them manually by entering them on the keyboard and pressing the OBR key.
What data should be sent to the TE2200? i.e. the barcode number is 9789745002500. Should the barcode scanner be programmed to send:
9789745002500
139789745002500
E139789745002500
E9789745002500
9789745002500E
Which one is correct?
I've tried 24 combinations of address code 0298 for 12000, 02000, 12020, 02020, etc. with different scanner flow control configurations.
Nothing has worked so far. I've made sure to clear flags after every operation of connecting the scanner, changing 0298, etc.
Please any help would be greatly appreciated. The more variables I can eliminate the better.
Thanks very much in advance.
jeff.beach@newyorkcasual.com
Where did u get the instrution on how to programm scanning plus in te2200.....i looked everywhere in the manul its no where in the book. Please help
Posted on Dec 13, 2009
    Scholar:
  • 90 Answers
I have set up the casio 7000 to use a metrologic orbit scanner. The scanner program is most important. I don't know what Cipher uses, but I think that is where your problem is. I will do some more research and get back to you.
The 9789745002500 is correct you will use a 13 digit number
Posted on Sep 23, 2009
  • Lucky Cash Register Sep 23, 2009
    I want to ask also did you allocate memory in the memory allocation in file 16, 40, 70, 71, 76?
    In the 298 parameter 12000 should be the right setting. Also on the scanner itself it must be programmed. The orbit scanner would use these set codes
    Enter /
    Recall Defaults
    Enable UPC Prefix ID
    Disable LF
    Odd Parity
    8 Data Bits
    1 Stop Bit
    Enable RTS / CTS
    Transmit UPC-A Check digit
    Expand UPC-E to 12 digits
    Convert UPC-A to EAN-13
    Exit
    Usually the scanner will come with a booklet of scan codes to set it up
    Chris
We have purchased a large quantity of Metrologic Barcode scanners for several years. Most of the models are the rs232 to keyboard type with the Softcom application. While upgrading systems to Windows 7, we...
There should be a compatibility mode which will allow you to run this software. Right click the application shortcut and you should find a compatibility mode in one of the tabs there.
Mar 30, 2011 | Metrologic Instruments HoneywellMetrologic...
I Have a new symbol scanner LS1902T-1000, whose software/Driver got missing, when i tried to read the bar codes, the unit beeps and a green light come on but I do not see any thing in the screen Please...
Hello Sabrina,
it depends much on the connection between the scanner and computer. The good sign is that the scanner is set correctly to scan the barcode. You need also scan the correct barcode for the connection art. Please scan from the Product Reference Guide the Barcode for USB, RS232 or Keyboard Wedge.
The Product Reference Guide is located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Oct 22, 2010 | Symbol Cobra LS1902 Handheld
Symbol Model LS 9208, Bar code Scanner loaded factory setting, its scans(beeps) but does not display /show in the notepad.
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Aug 21, 2010 | Symbol LS9208 Hands Free Barcode Scanner
Casio TE2200 Cipher 1000 CCD RS232 scanner still not working
Jeff I feel your pain. I have never use a Cipher scanner, I stick with the well known brands like metrologic. I see them for about 385 each. I know you can get one for less used or online. When I set up the scanner I usually use the booklet and scan the codes into the scanner itself. Take 20 seconds or less. You probably did that but just checking. My answer is at this point and since its not in my shop, is, Metologic. Your casio's com2 is where the scanner should be and 298 should be 12000. I understand you can get it to work with hyperterminal but, that in essence means that the scanner works but not necessarily with the settings. These kind of issues are 99% of the time in the settings. The list I sent on the last message was the barcodes used to program the scanner. you know expand ean13 etc. that is where i still feel it lies.
Im doing my best I may have to set up my own scanner on my 2400 and see how it works.
Chris
Sep 24, 2009 | Casio Parts Cash Register PC Desktop
Casio TE-2200 Scanner does not work
Hi Jeff,
1. To know whether scanner is doing ok with TE2200: After u do the flag clear the R/J printer will print a piece of paper , if u didn't see "02-98 5803" at the bottom of the receipt, that means TE2200 can detect the scanner correctly
2. For the Graphic Logo :
2.1 make sure u have ur picture in the size of = 384x168 pixel, and it have to be in "bmp" format.
2.2 Key turn to PGM
2.3 press 5 sub
2.4 Press [4] [7] Sub
2.5 press [1] [6] [8] CA Sub
2.6 Use Casio CV-10 software to send the logo to TE-2200
Sep 21, 2009 | Casio Parts Cash Register PC Desktop
I have got scanner 1000 but cannot scan the barcodes i have got. like TA010304, when i scanned it, other weird stuff would appear like 06^OX... anyone can help me? Thanks.
Hi there, you may check the settings of your scanner software, go to start>programs and check the scan software utility and from there check the settings of the scanning page/are so that it would see those barcodes you need.. or may lighten the scan settings as well.
Jul 07, 2009 | CIPHERLAB 1000 Handheld Barcode Scanner
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
Can't figure out scanner
with most barcode readers you need to configure it before you can use it, this is usually done via a barcode book whiich configures everything that the gun can do....everything from how it communicates with the pc, to the types of barcodes it can scan
Jul 01, 2008 | CIPHERLAB Computers & Internet
CIPHERLAB 1000 (serial ) Driver for WinXP
you dont`t have a driver for serial comm.open hyper terminal on com port where is the scaner.read a code and you wilkl see the numbers on the screen.If you want to work with some windows programs change that barcode for usb or ps/2 variant.
Jan 15, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Casio Parts Cash Register PC Desktop Logo
569 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
