Question about HP Laserjet M2727nf Multifunction Printer
We are on our 3rd HPLaserJet M2727nf printer as we've consistently had problems with the printer going into a sort of hibernation mode in the middle of the day. The projects we send do not print and the keypad stops working. We have to turn it off then back on, and then our documents will print. How can we fix this? I've spent hours on the phone with HP and they cannot help.
  • incrediblech Sep 23, 2009
    Thank you. How is this done?
I had this problem, According to HP it is a known fault with the motherboards on some of the earlier manufactered models, the fix... Replace the motherboard, luckily my m2727nf was still under warrenty
Posted on Jan 23, 2010
  • 30 Answers
Did you try updating the firmware, update the printdriver to HP PCL 6 driver
Posted on Sep 23, 2009
    President:
  • 1,653 Answers
This is either an issue withthe printer driver, the printer ecm firmware or it is not recognising a wake up on oan signal. Try connecting directly to the prinetr if possible rather than using the LAN connection.
Microsoft Operating System protocol is to install first and then always have drivers and applications install on top of them. More often than not the drivers are outdated and rendered unusable by many of the operating system updates and then need to be updated themselves by the relevant vendor or have to be uninstalled and then reinstalled. Of recent times this has become more and more of an issue due to complexities in the registry and in the COM fabric of the operating system. The registry often gets clogged up with superfluous entries and needs cleaning out to improve performance just like the HD inside the PC needs defragmenting occasionally. Unfortunately when many of the updates from Microsoft and many other software vendors are applied they leave their old entries in the registry and just write new ones - simply because it is convenient and easier for them to do so.
Uninstall the application and drivers using the HP remove utility. It is not sufficient to use the Operating System uninstall as it does not work that well. The Registry, Application, Folders and drivers need to be totally removed.
A registry clean is recommended. You can do this by downloading a free 30 day use of Ashampoo from www.ashampoo.com and clean up your system of all the unnecessary entries. I have been using it for a few years now with grate success and no problems. You can always restore any deleted entries before binning them forever.
Once completed then reboot the PC then reinstall the HP drivers and application. Make sure these are the latest ones available from HP support for your operating system at
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3377076&taskId=135&prodTypeId=18972&prodSeriesId=3377075&lang=en&cc=us
How do i turn hibernate mode off
Not knowing your laptop or OS? I'll give you a sort of answer. Go to Control Panel, Power Options, open . Win 7 in the Tray Notification Area, right click on power icon, open power options, advanced options, look for hibernate. That's the best I can do with the info provided.
Nov 29, 2012 | Computers & Internet
HPLaserJet P3005 keeps going to sleep mode
Good day.
Try this one,this might help. Go to Setup menu,that would be the wrench icon,then Tools>Energy saving mode>Turn off energy saving mode. Please tell me if this solved it.
Jun 19, 2011 | HP LaserJet P3005n Printer
Ink does not stick to page on m2727 when printing cardstock. We have tried using different paper settings.
Are you using original HP toners or 3rd party (refills)? We have had issues with some 3rd party toners not bonding properly on heavier media. How heavy a cardstock are you trying to print on? If it is heavier than the highest rated paper for this printer then it may not bond at all, regardless of toner used. The heaviest paper that HP rates for this printer is 43 lb/bond. A lot of cardstock starts at around 65 lb/bond.
Jun 15, 2011 | HP Laserjet M2727nf Multifunction Printer
The ink is peeling off the laser crystal clear labels. Why? My printer is a HPlaserjet 3050.
Are you using orignal HP cartridges or remanufactured cartridges? We have had a lot of problems with 3rd party toner not bonding properly and installing an original HP cartridge usually fixes the problem.
May 04, 2011 | HP LaserJet 3050 All-In-One Printer
Am getting 50.2 fuser error on hplaserjet m2727nf printer
50.2 error is an internal hardware error.
Turn off the power using the switch, and wait at least 30 seconds.
Do not use a surge protector. Plug printer directly into the wall outlet.
Power on. If the error comes back, contact HP.
Feb 25, 2011 | HP Laserjet M2727nf Multifunction Printer
My HP Laserjet M2727nf is printing with a line in the middle of the document but only when the document feeder is used not the copy bed. Any suggestion on how to fix this?
Clean the ADF strip glass. This is the thin strip of glass that is right next to the larger document glass. There is usually something stuck to the glass causing the line.
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 25, 2011 | HP M2727NF Laserjet Printer
LG flatron w2061tq unwanted standby power saving mode
Go to "start>settings>control panel>Display>Screen saver>Power>
Turn off monitor : Never
System Standby : Never
I have tested and its working fine.
Thanks,
Viju
Apr 08, 2010 | Computers & Internet
HOW DO I CLEN THE DRUM FROM MY LASER JET M2727NF
This printer does not have a drum it has an etb which can be cleaned using the cleaning mode in the service menu, run it 5 times.
Al
Eliteprintersolutions@gmail.com
Mar 30, 2010 | HP Laserjet M2727nf Multifunction Printer
How re start my hp laserjet m2727nf, how delate
hold down the go button while you power on your hp laserjet.
Mar 19, 2010 | HP Laserjet M2727nf Multifunction Printer
HP Laserjet M2727nf Multifunction Printer Logo
779 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
