Question about GE WSM2700D Top Load Stacked Washer / Dryer
Squeaky Belt when dryer is running. However the dryer is working (heating) fine
  • GE Master
  • 909 Answers
Very possibly not the belt but the associated components like the drum: motor bearings bearing strips support:rollers (if you have them) etc. Truthfully i would just continue untill something malfunctions then do an extensive repair. Once you start repairing these small ****, it esculates into a relatively large expence.
Posted on Sep 23, 2009
Why is my dryer drum not turning correctly?
The rollers could be defective, a common dryer failure.
Dec 28, 2015 | GE DBSR453EBWW Electric Dryer
How do I fix a squeaky belt on a minivan?
Post question is automotive section?
Is belt squealing? or is there a squeaky noise?
Squealing would denote belt slippage... belt might be loose, apply more belt tension at idler pulley (if possible). Consider trying a spray-on 'anti-slip" compound.
Squeaky noise could mean a bad pulley bearing.
Oct 13, 2014 | Dryers
How to Fix a Squeaky Dryer
Squeaky dryer noise is a dry rotted belt or stretched and it is soon to break. Get model and make of dryer and go to your local used appliance repair man (or woman) and give them the info for your dryer and they should be able to help you out or it your are uncomfortable and unknowledgeable how to replace the belt, ask your qualified service technician to do it for you.
Nov 03, 2011 | Kenmore Dryers
My dryer making squeaky noise we open to check the belt. Belt is fine where should be the noise coming from?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 31, 2011 | GE Profile Harmony DPGT750EC Electric...
My whirlpool special edition 3 cycle dose not turn on but it gets heat the belt is fine, it was working fine then one day out of the blue i turned it on and it was not starting noticed it was still heating...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 26, 2010 | Whirlpool LEB6200 Electric Dryer
Dryer makes a squeaking noise when running
Check the following:
  1. Idler pulley - It keeps tension on the main drive belt and when it is worn, it can be squeaky and noisy. Replace then.
  2. Glides - Attached to the front bulkhead of the clothes drum for support. When worn, it can be noisy and squeaky.. Replace then.
  3. Rollers or wheels - They support the clothes drum. When they are are worn, you should replace the whole set of rollers at the same time.
  4. Blower wheel - It pulls air over the heat source through the clothes drum past the thermostats, then pushes it out the exhaust duct. It may wear out over time. If it is noisy, it may be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it.
Oct 26, 2009 | Kenmore 84152 Electric Dryer
Fisher & Paykel top load electric dyer makes loud squeaky sound
to be honest i doubt that a bad belt would make a squicky noise and for a high class dryer like that i would suggest just call repairman  they are very complex
Jun 08, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Nextra7 condenser dryer making squeaky noises
heatman101
tukuymhg
Feb 14, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
GE WSM2700D Top Load Stacked Washer / Dryer Logo
168 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
