Question about Belkin Ultra ATA/133 PCI (f5u098) ATA Controller
I cannot find a driver anywhere for my belkin f5u098 ide raid controller.
The drivers for this ATA Controller Card are resident in Windows, just like the Motherboard's onboard ATA/IDE Controller. If they don't autodetect and load make sure you are running at least Service Pack 2 for Windows XP and SP4 for Win 2000. Vista and later will have resident drivers.
Posted on Oct 10, 2009
Need manual for C51GU01
In the bios there's an option to configure SATA as "IDE", "AHCI", or "RAID".
If you don't have data to loose, try this. Install the drive, set the BIOS option to "IDE", boot to windows, install manufacturer's IDE/SATA controller drivers, restart, set the BIOS option to "AHCI".
AHCI stands for Advanced Host Controller Interface. There are rumors that setting AHCI without manufacturer's drivers will give you a BSOD. I'm not sure if you can recover it by switching back to "IDE", but it should be worth a shot.
Best of luck
Aug 13, 2012 | Intel Motherboard
Need win 7 drivers for SD SIL680-Raid card
try the vista driver it should work ok
32 bit driver is here http://it.us.syba.com/bin/silicon_image/sil680/SD-ATA133I-VISTA-32bit.zip
64 bit driver is here http://it.us.syba.com/bin/silicon_image/sil680/SD-ATA133I-VISTA-64bit.zip
if you found this useful please vote for me
Apr 22, 2011 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
Have an SYBA PCI IDE RAIDx2 and very urgent need the driver for Windos 7 Ultimate x64. The VIA site is out of service..!!
hi I found this link below for all syba driver updates and downloads, hope this helps.
http://it.us.syba.com/support_download/download/index.html
Feb 13, 2011 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
NEED DRIVERS LOST DISK SD-SIL680-RAID
you can download from web site of board if you can use the public libray system jim
Mar 25, 2010 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
Gigabyte ga-8i915p duo motherboard ide problems
RAID stands for Redundant Array of Inexpensive Disks.
The RAID system uses multiple number of hard disks to give a fast and fault tolerant storage using several disk controllers.
There are various levels of RAID, for info on RAIDs check out
http://en.wikipedia.org/wiki/Standard_RAID_levels
Apr 03, 2009 | Asrock P4VM8 Motherboard
Raid 0 on Intellistation 6221?
That particular work station comes with both IDE and SCSI drive interface controllers. The IDE drive should be used for your OS. The SCSI drives for your data storage. Now, the issue is to get the SCSI to work in RAID_0 as I understand.
You iwll need a RAID controller such as Adaptec AHA-3940AU WD SCSI Host Controller, which may be found on eBay (used) for a very affordable price. The driver software may be downloaded directly from Adaptec, so I suggest you do that in the iterim peroid, and store drivers on a USB thumb drive.
Hope this helps you.
Dec 21, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
Conflict between Promise Ultra133 and SATA RAID controller
Check that your RAID controller and onboard SATA controller aren't in a compatibility mode. You can put them in this mode while you have no SATA driver installed in Windows.
This tricks Windows into seeing the SATA drives as regular IDE drives. Your BIOS then has a spasm when it see's another IDE controller there, and just uses the card instead.
Make sure the SATA drivers are installed first, otherwise anything SATA will stop showing up. (and your Windows just won't boot if it's on a SATA disk and you take compatibility mode off) =-]
Aug 09, 2008 | Promise Ultra133 TX2 ATA Controller
Installing new seagate pata/100 hard drive and belkin ata/133 controller
There should be a tab on the back of the actual hard drive where you can switch it to CS "cable select", You just take the tab out of the slot that it is in and switch it to where the cable select is. I am sure that the drive is set to something different or it would be working.
May 24, 2008 | Belkin Ultra ATA/133 PCI (f5u098) ATA...
Belkin Ultra ATA/133 PCI (f5u098) ATA Controller Logo
239 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
