http://teral.ru/katalog_stiral_nyh_mashin/siemens_simens/?p=6
best i can do is google translate
F03 is
Drain alarm (water in the tank is reduced to one level in the allotted time plot )
you ran out of time for the drum to fill
{too low pressure}
use the hot water valve as the cold
block off the hot water intake
this way you have a low pressure valve for cold
or
1. There is a poor connection at terminals bilge pumps - seal the clamps, clean the terminals.
2. A malfunction in the bilge pump - clean the filter pump washing machine Siemens (Siemens) to either replace it.
3. There was a problem with the drain hose - hose to clean from pollution, eliminate the excesses, to restore the position of the drain hose specified in the instruction manual.
4. The pressure switch is faulty washing machine - repair of hydraulic water level sensor or replace the pressure switch.
