Question about Airstrike Bell 800 Frame Mount Bicycle Tire Pump
I don't know how to use my brother's Airstrike Bell 800 Frame Mount Bicycle Tire Pump. Can you please give me instructions on how to use it?
5 Suggested Answers
SOURCE: lost manual to Bell wireless bicycle computer
Here are some things the book doesn't tell you:
You have to completely reset the speedometer and lose your odometer to reset the MPH. Hold both buttons for 3 secs to get reset. (Remember to use the left button to walk through the setup process and use the right button to change the settings.) First set the wheel size using Ideluna's settings above on this page (right button to change the setting and left button to go to next number). Next is MPH/KPH, after wheel size setting, push left button again and km flashes. Push right button to change the setting to MI. Next is TIME. Push left button and you'll see the time. Hold down left button till 24hr appears. Push right button to change to 12hr. Then push left button to go to flashing hour. Change with right button. Then left button to go to flashing minute. Right button to change minute, hold down to change minutes fast. Now you are set up. Now the process changes, use the right button to walk through the menu and use the left button to reset. Don't push both buttons anymore unless you want to reset everything again. If you want to reset something just hold the left button down until 0. When you are in SCAN mode, push the right button to go to Time, To go back to SCAN once, hold the right button down - It will scan everything once and return to TIME. To go to ODO, push right button once, push again for DST, push again for MXS, push again for AVS, push again for TM, push again for SCAN to stay in SCAN.
Posted on Mar 13, 2010
  • 110 Answers
SOURCE: bell brand bicycle training wheels
hello there:
the training wheels are a simple procedure you will need to take the nuts off the back wheel and place the steel spacer and put over the axle then place the training wheel over the spacer and put the nut on making sure the the training wheels are not too low or too high.... best of luck to you hope the information is helpful
Posted on May 30, 2010
formeat
  • 6 Answers
SOURCE: how do I use the Bell AirStrike Digital Floor Pump
The gauge measures three different amounts. Be certain that you have it set to PSI. Then set the target PSI. The green LED indicator will then flash when you are within 5 PSI of your target and will flash constant when the target PSI is reached.
Posted on Aug 30, 2010
anupam19
  • 263 Answers
SOURCE: Where Can I get a new hose for my Bell AIRSTRIKE
Go to ebay.com
Posted on Mar 13, 2011
Resistance when I try to pump, no air enters tire.
Make sure that the end isn't bent and connects to tire good. You will here a little air escaping if hooked up correctly. If that isn't it make sure there is no obstuction in the air line. Release relief valve and let air out.
It could just be the end, your connection to the tire, or at worse a bad pump.
May 29, 2016 | Bell Airstrike 1000 Gauge Frame Pump
Airstrike Bell 1900 , the hose is ripped. What do I need to do? How to replace it?
Always a good idea to contact the manufacturer: The Bell Garage or a bike shop may be able to help. The pump may accept a different brand hose.
Sep 13, 2013 | Airstrike Bell 1800 Floor Bike Pump
I have a "Judge"
Sure, A new O-ring and a little grease, the same you use on your bearings to make a good seal.
Without seeing and feeling the actual pump, a sloppy O-ring will cause a loss of pressure.
You will also want to check the head and make sure the rubber still makes a seal around the tube valve, if not then that will need to be replaced as well.
Mar 20, 2011 | Airstrike Bell 1800 Floor Bike Pump
The tubing that leads from the pump to the tire is broken off right at the base? Can it be repaired? HOW?
Most Bike Shops carry repair kits for common pump brands and I wouldn't be surprised if some cross brand parts would work. eBay has many for sale.
"floor pump hose"
You might even be able to go to an automotive supply store and get some pressure hose yourself real cheap.
Mar 13, 2011 | Airstrike Bell 1800 Floor Bike Pump
Need new hose , where can I find this for airstrike 1800 model
Has anyone found a replacement hose for the Airstrike 1900? And/or instructions on how to replace it?
Jun 15, 2010 | Airstrike Bell 1800 Floor Bike Pump
How do I use the Bell AirStrike Digital Floor Pump
Jan 02, 2010 | Airstrike Bell 1800 Floor Bike Pump
Should I add oil to the top opening (where pump shaft enters same) if it's losing air out this opening when I go above 40 psi?
It's not the opening that is the culprit. Those bell bicycle pumps have an o-ring for a piston seal, and this ring needs oil from time to time. The oil that should be used is as thin an oil as you can find, something like 3 in 1. You should disassemble it to check to see if the plastic piston isn't cracked. (They do crack from time to time, and might be what is wrong with your pump.)
Nov 25, 2009 | Airstrike Bell 1800 Floor Bike Pump
Bicycle tire pump won't pump.
If you can? unscrew the two pieces of the pump clean and oil it. W/D40 works pretty good.
Apr 24, 2009 | Airstrike Bell 800 Frame Mount Bicycle...
Airstrike Bell  800 Frame Mount Bicycle Tire Pump Logo
46 people viewed this question
Top Airstrike Cycling Experts
John Egan
John Egan
Are you an Airstrike Cycling Expert? Answer questions, earn points and help others
