Question about Sony Playstation 3 (PS3) Console
I try to my console on and it does turns on for a second and then shuts itself off and blinks red. its not hot or anything and idk whats wrong with it. my only controller was dead could that be the problem?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
Blinkin red light usually means hardware failer the only 2 easy tricks to try that wont void your warrenty is
#1 remove the hard drive and boot it up without it and see if it boots and says no hard drive then shut it down and plug the hard drive back in if it works now then was just a drive error if it goes back to blinkin you have a bad drive.
#2 the fan test that also seems to clear any over heating or other blinkin light problems --- turn the ps3i try to my console on and it does  turns on for a - 2.gif off for 40 seconds by the switch on the back then hold down the eject button and flip the power switch back on while still holding the eject button and see if that clears it.
Posted on Sep 24, 2009
4 Suggested Answers
flowtron2k2
  • 95 Answers
SOURCE: bar light turns from green to yellow to blinking red
this is similar to the red blinking lights on the xbox360...it seems your cell processor has overheated resulting in a cold solder joint or worse bridged solder involving the BGA array...I have had some sucess in fixing these albeit limited. sony charges 150 plus state tax and sends you a refurbished unit.
Posted on Nov 11, 2008
  • 14 Answers
SOURCE: PS3 won't power up.
THis issue is a motherboard issue, sort of like the 3 red lights on the Xbox 360.  It will need to be repaired.  If it is under warranty then send it to Sony, otherwise we fix this issue in my repair shop, just go to joegoods.com
Posted on Apr 02, 2009
  • 64 Answers
SOURCE: WHEN I TURN ON MY
Most of the time this is caused by dust buildup in the console causing it to overheat. Use canned air or an air compressor to blow the dust out of the console. Do not use a vacuum as they can create static that can damage the electronics. Worst case scenario the console will have to be sent back to the manufacturer to have an electronic component replaced.
Posted on May 05, 2011
Atv help I have a sunl 6gdhx 110 atv . It was
first look down by engine itself should have three wires going in where stator assbly is located one is red ,black and other could be any color red should be hot when key is turned on,try jumping a wire from bat, to it
Sep 04, 2014 | ATVs
Ps turns off straight away. was midway though a game when suddenly shut down and then when trying to restart the system, it automaticly turns off. no ejection option available ...or anything for that...
It sounds like yellow light of death. If you answer yes to these questions then thats what it is. I have a step-by-step instructions on how to fix it.
1. When you turn your console on, when it turns off does it beep 2 to 3 times before shutting down?
2. When it does shut down right before it does pay attention to the lights, do you see a yellow on blink once for a split second?
3. Afte the console shuts completely off does the red light just sit there and blink?
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Feb 25, 2011 | Sony Playstation 3 (PS3) Console
I was playing my playstation 3 and all of a sudden it shut down and began to blink a red light. It did this a second time. What is wrong with it? Please help?
Your problem is yellow light of death which can be fixxed with heat gun hot air gun and the right person or your power supply internally is going out.
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
My playstation turns on for approx 15 seconds then turns itself off again, whats wrong?
I'm guessing that there is a red light blinking when it turns off.
if so,
it has overheated.
Let it sit for a day and keep it away from carpet, anything that makes heat, and atleast 4 inches from everything in general.
If it escalates to turning off immediately and flashes yellow and red, then you have a dead system. To fix this you need to send it to Sony if it's in warranty, or wiredextreme.com if it's not.
Because wiredextreme.com is better in so many ways.
Feb 13, 2010 | Sony Playstation 3 (PS3) Console
When I turn on the PS3 it starts , 3 beeps then red blinking
Its probably an indicator that their is dust build-up, or over heating so it shuts itself off. Clever what sony did because with xbox 360's they don't, they keep running until it probably melts the internal hardware. Well hell I wouldn't know I just read that from some other opinion. But yeah just wait a bit for it to cool down or spray your ps3 with compressed air for dust.
Jul 12, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 at power on, light becomes white then blinks red
Probably and overheating problem. Here's what I suggest:
Try using some compressed air and cleaning the vents out below. If that doesn't work then you'll have to remove and replace the thermal compound on the GPU and CPU.
You might also consider a System Restore if you can do it before it shuts off.
Jan 24, 2009 | Sony Playstation 3 (PS3) Console
Camera on for 5 seconds red flashing light then turns off
that definitely sounds like a battery problem.
when you charged the battery, did the light stay red, and then turn green when it was finished?
if it flashed red, try this:
MATERIALS: 9 volt battery, 2 pieces of wire the same length, casio battery
DIRECTIONS: connect the + sides of each battery with a wire, and the - sides of each battery with another wire. [I just held them there, but maybe you can tape them if you're having trouble.] Hold it for 30 seconds. Then try charging it. If it doesn't work keep trying it until it does. TRUST ME! It took me 5 times to do it effectively.
If your battery has gone too long without charging, sometimes it won't charge correctly any more. So do this.. IDK why it works, but it did for me!
Nov 19, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
PS3 Turns Itself off and wont turn on
sorry mate i cant fix it but my buddy has a problem with his also
his ps3 freezes even in the menu screen and during video chat it shuts off
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
94 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
