Question about Garden
Im looking for a service manual or instructions on carbuerator adjustments for a poulan pro mod # 331 weed trimmer
  • 546 Answers
Visit www.zama.com --excellent site shows applications & theory of carburetors
Posted on Sep 23, 2009
Fuel mixture for poulan pro heavy duty brushcutter 331 sn 01254n500330-1is needed asap. lost my manual!!!!!
40:1 mix, 3.2 oz of 2 stroke oil for every gallon of gas.
Link to the manual is below
http://www.poulanpro.com/ddoc/POUO/POUO2001_USen/POUO2001_USen__530088910.pdf
May 27, 2011 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Can not adjust carburetor
Yes...they have them on Ebay. Normally you won't be able to get one from a small engine repair place or dealer unless you're "in" with them. You can make using a 22 gauge-18 calibre electrical connector. (Quick disconnects-female) They need to be female spade terminals and you can stick um on the end of a screw driver and then push them down over the round-splined heads of the L and H adjusting needles on the carb. Probably have them at auto parts store....if not Radio Shack.
Jul 12, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
I need a twist n Edge weedeater manual to find out how to put more string on the spindle
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater RTE 115 Trimmer Manual.
Jun 26, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
New poulan pro will not start
when I bought mine. The weed eater didn't start right away so I took it back where I bought it and I had them look over it. when reading the manuel It said that it might not start right away becuse the fuel mixture needs to be adjusted on the pro prolan pp125 weed eated. so we utilized what we had around us and found a tube. adjusted it and it started right up.
May 22, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Adjustment for carbuerator on Poulan Pro Chain Saw/ Model 221/ 40
Are the jet screws fitted with slot heads or 'D' heads? 'D' heads require a special tool to adjust and are not available to the general public, so you are stuck with taking the saw to a servicing dealer for adjustment. Slot head screws can be turned with a small flat-blade driver by anyone. In case you have owner-adjustable heads, try the following: Turn both screws CW to stops (lightly), then back each out 1-1/2 turns CCW. The engine should run with this basic setting. Warm up the saw, then pull the throttle full on. Turn H needle CW until the engine speeds up somewhat, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW until the engine idles fairly well, but allows the engine to 'follow-the-throttle'. Adjust idle speed so that the chain stops turning, but the engine continues to run. Hope this helps!
Apr 30, 2010 | Poulan 14" Electric Chainsaw
My husband took his Poulan Pro 31 cc weed eater/trimmer apart and now needs an engine diagram to put it back together. Where can I get a downloadable one ?
Go to the Poulan web page http://www.poulanpro.com/node6556.aspx and enter the model number of the string trimmer. If the trimmer is a Weed Eater brand (owned by Poulan) then go to this page http://www.weedeater.com/node6507.aspx. I think you can also locate older model manuals in their archives.
Apr 10, 2010 | Poulan Garden
After rebuild only runs on half choke.Adjusting screw doesn't help
The rebuild you did is correct, but did you clean the small ports in the carb.? I use a Den Tek Brush (used for cleaning teeth). They work great for this job. You may also want to check the small screen in the carb. The smallest of particles can cause this problem.
Jim
May 25, 2009 | Poulan Garden
Garden Logo
196 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
