Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
My 5150 dell will not start. I see only flashing orange licht behind the start button.
    Problem Solver:
  • 10 Answers
Check power supply any beeping is fan running
Posted on Sep 23, 2009
  • 3,153 Answers
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Orange flashing light on a dell dimenson 5150 computer won't start up
The orange flashing light on the power button is an indication of power supply failure.
Your Power supply unit needs to be replaced.
Aug 11, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
Start button flashes orange and will not turn on pc then will suddenly start up. Whats happening here?
The orange light on the power button normally indicates power supply failure.
If the system does turn on after a few seconds, this may indicate damage to the power supply and it may need to be replaced.
If you feel confident you can open the side of your PC and see if any of the capacitors are broken and leaking. "Bad caps" on the motherboard can be another cause of slow power ups.
Aug 07, 2010 | Dell Dimension 5150 Intel Pentium 4 w/HT...
My Dell Desktop Dimension 5150 does not start sometimes
loose connect or mother board problem (is your os & HDD is OK ?)
Jun 24, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Flashing orange light on power button of Dell Dimension 5150 ...
If you experience the dreaded blinking orange power light, make sure to check your motherboard for blown capacitors as well as corrosion on the motherboard. Looks like the photo below.... if you see this then a replacement motherboard is needed.
Aug 04, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Flashing Orange light, computer wont boot
Below is the link to the NoPower, No POST, No Video troubleshooting.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=&treeid=011360B8243248349C306481A954B356&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=en&toggle=&dl=falseFollow all the steps without skipping any and if there is no hardware failure,this should definitely resolve your issue.
Hope this helps. Please rateyour feedback!
Thanks,
VJ
Mar 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Orange Light
you need to replace the motherboard lithium battery. Looks like a watch battery.
Sep 07, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
163 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
