Question about Maxtor OneTouch 4 Mini 160GB External USB 2.0 Hard Drive
My maxtor doesn't show up in my prgrams or on my sys tray; tho i can can access it, it is no longer actively backing up
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 23, 2009
  • 53 Answers
Now if you want to use you have to lose your data simply plug it in and right click on my computer go on manage and click on disk management there you will see your maxtor format it by following instuctions
High CPU usage from interrupts and ACPI.sys
go to bios see if the cpu cap is off or on also go to system in computer and adjust all index options can also try cpu usage controls in control panel
Feb 28, 2013 | Computers & Internet
How to reset password in Panasonic KX-T7731 in the program
Do you have a back-up file of the last configuration?
You can use the configuration software to read off the password.
Jan 06, 2013 | Panasonic KX-T7730 Corded Phone
Maxtor Personal Storage 3200, after years of use my Vista machine now tells me that the USB Device isnt recognised.
However last month I found that the Maxtor is no longer recognisable to my machine. Reading through related postings on other sites it appears that Vista updates from Microsoft may be the reason why this functionality has suddenly ceased. I presume the security updates in particular may have meant that the Maxtor 3200 is also considered a potential threat. The question is who will take responsibility for resolving this issue of Maxtor 3200 users no longer being able to access their back up files via their Vista based machines. Personally I believe the onus is with Microsoft
hope this helps
John
Feb 24, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
I am looking to reload my files from a Maxtor One touch 4 750 GB external USB - I was under the impression that the drive had been backing up files for the last year - I can only find files from September...
Have you changed any of the files since backing them up? If not that is why they show a Sept 2008 date. yes you can be slective, depending on which backup and restore app you are using. Effectively only highlight the ones you want to restore and then activate the restore process.
Nov 13, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Drive powers up but will no longer be recognized by my computer. Drive activity light does not flash.
Sound the interface cable going to the drive. Replace the cable, they are usually resoanable price.
Oct 17, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
Maxtor One Touch III 160GB is not accessible - corrupted or ...
i had the same problem, i have removed the hdd cover and manually rotated the disc few times, it worked for 20-30 minutes, but it was enough to recover my data
Aug 20, 2009 | Maxtor OneTouch III (T01E160) 160 GB USB...
Paper Tray Oki /Xante ?
It sounds as if maybe the trays are not configured in your software. Access the printer driver and make sure that the additional trays are enabled. Under the Device Setting tabs, if on PC, available trays, ensure that you have the correct number of available trays selected.
??? If that doesn't work, you may want to check back with Xante to make absolutely sure they do not have the trays in question.
p/n 250-100075
Jun 19, 2008 | Xante CL30 HSE Laser Printer
Maxtor external back
plug in your external drive, and note it,s letter ( assigned device name ) i.e F/G/H et,c.
open your c:/ drive. highlight which items you want to copy over.
left click to highlight. then right click/Options/scroll Down Send to DriveF/G/H
And transfer, this should transfer what you want from 1 drive to another. But Don,t try to copy Windows. you.ll have errors as some of the sys files, will be in use whilst transfering.
mike @ compurepair.
Feb 20, 2008 | Maxtor Hard Drive
Maxtor OneTouch 4 Mini 160GB External USB 2.0 Hard Drive Logo
125 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
