Question about Samsung LE26R73BDX 26 in. HD-Ready LCD Television
Digital Tv stopped working
When I switch over to digital TV I am stuck on a single channel and can not change channels, see the digital menu, the guide text etc. In fact the only thing that I can change is the volume. The tv works fine for analogue television and was fine for digital until last week.
Any suggestions gratefully received.
  • Anonymous May 23, 2008
    I am experiencing exactly the same problem anologue TV is fine but i am stuck with BBC1 on digital TV.
  • Panso Jun 09, 2008
    Hi I have exactly the same problem. Did anyone figure this out?
I have got samsung 40 lcd is working fine but dtv got stuck on one channel. Its not moveing from one channel I have tried everything. Its not workig. please can you email me your suggestion to solve this problem.
Email address: fazalhareef@yahoo.co.uk
Posted on Apr 19, 2008
WHAT is this tv digital ?
Dear Friend,
First, search for available air channels by going to you menu and then search for channel setup.
Second: change the option from Cable to Air Channels.
Third: after performing the channels setup you should be able to see free channels trough the air.
Good Luck!
Aug 06, 2014 | Shopnbc Insignia 39", 46" or 55" Full HD...
Jvc hd56g786 channels stuck on digital cant get them changed to analog
Using the television's remote control, enter the user's menu. Search for video input and change from cable to antenna. If still experiencing difficulty, visit the JVC website and download the owner's manual to learn the procedure of changing the video input type and deactivate the television's digital decoder.
Dec 22, 2013 | JVC Televison & Video
Can u explain how to set up the television system with my digital television box.
The digital box should have a round threaded output connector on its back panel. These are usually marked "OUT TO TV" or "RF OUT" or something similar. There may also be a slide switch nearby to select channel 3 or 4 output to the TV. On some boxes the output channel selection is through and on-screen menu. You only need to connect the output of the digital box to the TV's antenna connector, then tune the TV to channel 3 or 4 depending on the box setting. Leave the TV on that channel all the time and do your channel changing on your digital box using its remote control.
If your TV has an AV input for connecting a device like a VCR or DVD player, you can probably connect the digital box that way. Most boxes provide stereo audio and video outputs, and you will get a clearer picture and sound if your TV has the input jacks. If your TV is not stereo and has just a single white input jack for audio (instead of red and white ones for stereo right and left), you'll need a Y-adapter to join the audio outputs from the box together to feed into the TV.
On the off chance you have a digital box with no RF output (I've never seen one since they need to work with older TV sets, but I don't know evey model), and your TV doesn't have AV inputs, you need an RF converter. The converter takes the audio and video signals from the digital box and generates the channel 3 or 4 TV signal that your set can pick up with its tuner. You can find RF converters at larger retailers and online.
Dec 12, 2010 | Disney 13" TV
I canot see my digital channels, the tv is stuck on 1 channel.
You can try to reset it by unplugging it let it sit for a minut or two count to ten and least then plug it back in this lets the micro reset itself
May 09, 2010 | Televison & Video
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
Hitachi T.V. remote CLU3842WL will not change channels.
There are two possibilities: either the channel memory has been lost due to the TV being unplugged for an extended period or the digital tuning system has a defective component. First thing to do is go into the TVs menu system and try to re-scan the channels. You may find that you can change channels after doing this. If its still not changing channel, the digital tuning board will have to replaced.
michtech
Feb 15, 2009 | Hitachi Televison & Video
TV gets stuck on channel, won't advance past channel 7.1
Try doing the Channel Search again. See if that helps.
If not, sounds like the Digital Board could be defective. Since this TV is brand new suggest calling your local sharp authorized service center to replace that board under warranty.
Mar 16, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Wharfedale LCD3210AF Television- Digital problems!
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Ghost in the channel selector
the problems due to the microprocessor on the remote reciever present inside the tv .i think the remote is normal working. as the only problem with your iinfra red reciever microprocessor.microcontroler circuit. Replace the IC to solve this. Check electrolytic capacitor coupled to the memory block of the micro processor. Contact service if you are not well verse doing all this rectification works. it is off high risk and caution
thank you !
Nov 17, 2007 | RCA F36650 36" TV
Samsung LE26R73BDX 26 in. HD-Ready LCD Television Logo
551 people viewed this question
Jerry Greenberg
Jerry Greenberg
