Question about Intel D945GNTLKR Motherboard
Intel P4 2.66 ghz processor Intel MOtherboard D945 EPI but motherboard gets overheating thermal heating i had changed te processor and the heatsing fan and i had applied heat sing paste through te board and processory i had checked with another smps also but getting te same problem bios also clear and only getting overheating in the back side of the motherboard particularly back of the processor area
  • 73 Answers
It might be that power unit give big currency to the mother board therefore it overheats.
Posted on Sep 23, 2009
I just need to figure out what the socket type this motherboard has for the processor so that I can find what processors I can upgrade my computer with. It's a g45t/g43t AM 3 V: 1.1 motherboard made by...
The socket type of ACER G45T/G43T - AM3 V1.1 motherboard is LGA 775. Here are the compatible processors you can use for this motherboard :
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition
(3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
Sep 13, 2011 | Computers & Internet
Put new d945gcl motherboard, put new power supply
Hello
Have you change the thermal paste(clean and reapply) and check the CPU heat-sink that is sitting OK or you have broken it?
Jan 18, 2010 | Intel D945GCL Motherboard
Intel Mother board D945 GNT. The system switches off due to excessive heating. The Processor temp ( from BIOS) shows 79 C. Please help. Changed the Heat Sink paste. does not help..Please suggest..
Thermal shutdown of the processor can be cleared up by the correct application of thermal paste or a liquid cooler block and an efficient heatsink and fan. It would seem that if you are running a system that is baking the processor at 79 degrees, there are serious processor demands being made. If you are overclocking or gaming with settings set to high, then you are going to have to go above and beyond the stock cooling rules or you are going to end up nuking your system. The thermal paste for a processor in a desktop computer needs to be about the size of an eraser head and then it needs to be spread very then across the processor, staying away from the very edge. The Heatsink has to be able to handle the demands of the system and the more fans the better. That motherboard should have several power points for fans, there should be fans pulling air into the case as well as fans pushing air out the opposite side of the case. Good luck
Jan 10, 2010 | Intel D945GCCR Motherboard
GHz upgrade
Yup, if your motherboard is working fine, u can just change another processor.
Below is the link to supported processor.
http://www.intel.com/support/motherboards/desktop/dg965ry/sb/CS-026603.htm
Jul 19, 2009 | Intel Computers & Internet
I want intel p 4 d945-gccr drivers
i want intel motherboard d945 driver for free download pls make a way
Mar 18, 2009 | Computers & Internet
Processor Overheating
It is important to use good quality thermal paste like Arctic Silver. You only need a very small amount on the heat sink. Too much is as bad as none at all. You care just trying to create a thin layer of thermal paste to fill in the tiny gaps between the processor and the heat sink. If this does not help an aftermarket heat sink with more fins and a better fan might be needed.
Mar 18, 2009 | Intel D865GVHZ Motherboard
Continuse restart my computer
Your CPU is overheating
1) Turn off computer and remove case side
2) remove fan from "heatsink" do NOT remove Heatsink "Usually this is stuck with solidified heat paste"
3) clean all dust and dirt from heatsink and fan.
4) vacuum out case Include behind power supply and video card.and any other fans
5) use stiff brush and vacuum outside of power supply
Reboot and see if still restarts if not everything OK
shutdown PC and refit case side.
This is a common problem on a lot of computers as the environment they are used in is usually dusty.
I do mine every 3/4 months and have no problems like this
Please when works give me a fixya
Jan 26, 2009 | Intel D101GGC Motherboard
Intel d845 gvfn display problem.
sir i have a problemmy mother board intell d845 epi/d845gvsr my mother board is cannot desplayed or display is not come but if i remove rame the mother board is give error beaps if i attach ram board is not displayed
Apr 25, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Cpu
How is your cpu cooler? Sounds like it could be a heat issue. How long before it freezes? Will it actually boot through to the operating system or freeze on start up? If it runs for a while then freezes it sure could be overheating.
Feb 23, 2008 | Dell 2.8 GHz Second Processor for...
Overheating? Processor running at half speed?
If the PC boot and start I believe your processor is OK, it's very unlikely that a bad processor can start.
Normally the average temperature of a processor is between 40-50 degree C. Your processor is overheating and it will not last too long.
Please look at the link here below http://processorfinder.intel.com/List.aspx?ProcFam=483&sSpec=&OrdCode=
and see if you can reconize your processor. The number on the left is the same number printed on your processor (You have to remove the fan again).
As a second test I suggest you to download the Asus manual of your motherboard and verify that you don't have any jumper that you are missing.
If you want to post the motherboard type I can further help you.
Oct 23, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel D945GNTLKR Motherboard Logo
219 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
