Question about Frigidaire ATF6000ES Front Load Washer
My washer has started making an amazing racket when it spins, even w/o a load. Sounds like the inner drum is somehow "loose". Any ideas before I take it apart?
  • 3 Answers
Als de trommel los zit moet je de washmachiene uiteenhalen en de roulementen vervangen
Posted on Sep 23, 2009
Loose Inner Drum on Tricity Bendix AW850W
Has the belt come off the pulley or the motor pulley? If not and it is in good condition has the belt stretched and not connecting properly or the motor slipped making the belt loose? Has the main pulley bolt come loose?
Dec 28, 2012 | Tricity Bendix AW850W Front Load Washer
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Ge fornt load washer mod #wcvh6260fww the inner drum chatters violently in hi rpm spin-- not to be confused by the entire unit shaking-- the inner drum only
I'm having a similar problem. Mine sounds like there is something behind the drum, like maybe a coin or loose nut? It screeches horribly.
Jul 30, 2009 | GE WSXH208A Front Load Washer
My washer makes aloud noise when on the spin cycle. HELP I Started a load of laundry and it washed fine until the spin cycle. It started making a terrible noise.
sounds like the bearings have worn out at the back,to check this open door and with your hand lift chrome inner drum up and down if you feel like a knocking noise then its bearings,
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Eurotech front loading washer, noisy on spin cycle with load.
Hi, could be one of at least two things - if the inner drum can be moved up and down by hand more than an inch when you grab it through the open door it could be the drum bearings that have failed - not good. Usually accompanied by a grinding noise and dirty specks on the clothes.
If the outer drum is really loose in the casing - check with machine unplugged and top removed - then one or more of the very strong springs at the top or the telescopic dampers at the bottom might have come off or broken from it's mounting.
Hope this helps!
If it doesn't, please hold off the rating button and add a comment with more details so I can try to help you further. Cheers, D
Mar 26, 2008 | EuroTech EWF172 Front Load Washer
Frigidaire Front Load Washer Making loud racket in last spin cycle
try pulling off lower acess panel. theres apump in rigth side corner . does it sound like theres something gaught in the squeeze the hose, try opening the door assy can you lift up on the inner basket. does it appear to have a bit of laterral movement???? how old is it???
Mar 13, 2008 | Frigidaire GLTF1670A Front Load Washer
Maytag Washer Noise While Spinning
Most washer models have snap-clips holding the front of the top panel down, with hinge-like clips at the back. Carefully pry up the top panel on the front of the machine using a tool that won't scratch the finish, such as a plastic or wooden wedge. If it does not pop loose fairly easily, then carefully examine the back of the machine to see if this is a rare model that has screws holding down the top panel. (But really, it _should_ just pop loose.) Once the top panel is tilted up to expose the inside, you should be able to see everything you need to see inside the body to evaluate a spinning drum problem.
Aug 04, 2007 | Maytag MAT13MN Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
167 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
