Question about Air Tools & Compressors
I need the air filter number on a compressor porter cable 80gl 175psi the model number is c7550
    Problem Solver:
  • 9 Answers
The Filter number you are asking for is A03157. The can be purchased at most local tool or compressor repair shops for around forty dollars. If none of the local shops are able to help you might try tryping the filter number as a search online. Hope this helps.
Posted on Sep 24, 2009
I have a porter cable 80 gallon compressor, model c7550. the switch stopped turning it on and off so i have been using the breker it is tied into. well now it wont epon. it just hums like it is stuck. when...
Check for three potential problems. Bad capacitors and or leaking in-tank check valve or low voltage. Check voltage with meter. On 220 v systems you could have lost one leg giving you only 110v. Check caps with meter and verify that they are within 90% of rating. Finally, if the checkvalve is leaking air back into pump, motor will not overcome pressure at start. If no pressure in the tank, the motor will start even with bad checkvalve. Good luck
Nov 12, 2012 | Air Tools & Compressors
How to remove muffler intake from Porter Cable CPF6020-1 air compressor
To remove the air filter intake muffle you will need to remove the 4 screws that hold the head on to the pump.
There is a O-ring under the head you will want to put a little vasoline on before you reassemble the head back to the pump.
The new muffler kit should be the KK-4981
Sep 10, 2012 | Porter Cable Air Tools & Compressors
The manifold which holds the Air Hoses and control valve and gauge is broken and I need a new one ,dont know the part number
We repair lots of compressors with broken manifolds. Most compressors now use a manifold with a built in pressure regulator. We are not able to find exact matches so we use a manifold from porter cable or make one out of pipe fittings. If your compressor was made in china, most likely the thread and tubing sizes are almost impossible to match. To use porter cable parts, go to dewalt service center or to porter cable dealer and find close match then use that model number for ordering your part. Check closely that parts/thread/fittings will work.
Jan 29, 2011 | Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air...
Need a rod for an oil run porter cable air compressor model c3151
Ok, the post shows 2 model numbers, so I will provide links for both. Be sure to only pay attention to the model number you actually have.
For a model C3151, an oilless compressor, the only way to get the connecting rod is by buying a piston kit, there is no individual replacement. KK-4835 is the part number and it runs about 50.00.
It can be purchased here.
http://www.ereplacementparts.com/piston-cylinder-and-ring-replacement-kit-p-58708.html
Now if you have a C3551, an oiled compressor, the entire Eccentric Rod Assembly will have to be replaced. The part number is Z-D22207 and it runs about 100.00.
http://www.ereplacementparts.com/assembly-conrod-eccentri-p-62701.html
I hope this helps.
Dec 04, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
I need a new piston ring for a 6 HP Porter Cable air complrssor. It is made of some sort of fiber or perhaps teflon like material. I made a leather one but it just did not last very long. the model...
The part number is DAC-308 and you can order the part from www.msservice.net or you can also try www.allpartsinc.com
You wont need new o-rings for the head just put a little grease on the o-rings and install them again.
Nov 06, 2010 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
Porter cable stand-up air compressor starts but air won't fill up
Might be the unloader valve is stuck. if so there will be hissing noise from switch assembly and you may have to get a new one.
Jun 04, 2010 | Porter Cable C6110 150 PSI 25 Gal OilFree...
My air compresser says to reset torque after 24hrs. use, how do I do that.
Head bolts are generally 25-30# and should be reset after first 24hrs continuous.
Mar 28, 2010 | Porter Cable 175 PSI 80 Gal. Oil-Lube...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
