Question about RIM BlackBerry Storm 9530 Smartphone
Why does my Storm sometimes not receive text messages ?
5 Suggested Answers
  • 12 Answers
SOURCE: Outgoing SMS Text Problems
check the blackberry fqa.com you will find your answer easy
Posted on Jun 01, 2009
asber
  • 291 Answers
SOURCE: my samsung corby s3653 cant receive text messages
if this happened from the beginning after purchasing your phone, it would help you if you bring it back to your phone dealer mostly if it's still under warranty.  but if this issue just comes up now, and you didn't encounter this issue before, it is a network provider problem.  however, since you are the phone owner, you may want to restore it to its factory settings and check,  here is the code for it but let me remind you that you will lose all your settings once you decided to hard reset it. so you need to back up your files first once you decide to restore it.  1.  switch off phone 2.  remove battery, sim and sd card 3.  reinsert battery and switch the phone on 4.  on your keypad, type the code *2767*3855# 5.  after successful hard reset, reinsert everything again,  6.  try sending a txt message to your own number and observe.
take care.
Posted on Mar 11, 2010
caroldon
  • 17130 Answers
SOURCE: When receiving text messages sometimes I receive a
You phone is not supporting the media that your friends are sending to you. Perhaps your friends are having more advanced phones and they must be sending some animated texts that wont support your phone. Unless your phone software is faulty this could be the issue and you can ask your friends to test out with plain test to confirm. IF this is not the case try resetting the phone to factory settings. Since you have not mentioned the make/model of the phone , I hope this advice helps. Good day.
Posted on Jul 24, 2010
localwonder
  • 6784 Answers
SOURCE: I have a BlackBerry 9530
HI. This is really an issue with the the phone number format or the actual recipients phone service. You must be sure that the recipients phone number is correctly inserted into your device as displayed below:
XXX-XXX-XXXX Example: 742-887-8854 (Area code-prefix-suffix)
The area code must be inserted along with the actual number you are sending the message to. if not, the device and service will not be able to send the message to the target device, properly. The format of the entered phone number must be entered correctly as displayed above.
Now; if your format is correct, this will be an issue with that particular recipients phone service provider or some sort of network congestion. In this case, continue to send the message until it is accepted when the network congestion starts to level out or subside. Make sure you have not blocked that particular recipients phone number for any reason in the past and forgot to unblock it and pay attention to your phone signal bars. If the bars a lower than tow bars, you wont be able to send messages until your phone strength returns to four bars or above.
If none of these suggestions prove to be a positive reflection on the issue, you will then need to contact your nearest service provider for a repair ticket and hardware flash procedure.
Posted on Aug 24, 2010
Why can't i receive some text messages, but can others
It could depend on your coverage/reception at the time the text messages are sent to you. Poor coverage/reception (few or no bars) sometimes causes delays in messages being received, or can cause you to miss messages.
Or perhaps your plan doesn't include MMS messages (multimedia messages, such as those with pictures). Check your plan or call your provider to determine if you can receive MMS messages.
Jun 11, 2014 | Kyocera Cell Phones
My iPhone 4 sends an receives iMessages no problem but normal text messages to none iPhone users are different It says my text gets sent but never gets received I have tested this. My phone is fully u
The user NOT receiving the message needs to go to settings for Messaging and turn iMessage off then on again. It has to show 'Receive messages at' settings with either phone number or email address. The phone will sometimes fail to automatically do so.
Nov 20, 2012 | Cell Phones
I bought a blackberry storm 9530 on amazone. Its unlocked because i am in netherlands antilles and can make and receive calls and text messages but i cant browse the web or use BBM. I think Verizon has it...
Seems like your phone network is locked which needs to be unlocked. This can be done through Blackberry unlocking codes with IMEI. You can unlock your Blackberry Storm 9530 from them since they provide trusted and affordable codes to all their clients. i hope this would help.
Jul 29, 2011 | RIM BlackBerry Storm 9530 Smartphone
I can't send or received text messages
check the msg centre of your phone and enable it,if problem persist call your service provider to send the msg centre of your phone to you.
Jul 17, 2009 | RIM BlackBerry Storm 9530 Smartphone
Jun 01, 2009 | RIM BlackBerry Storm 9530 Smartphone
Can't receive text messages
How often do you power your phone on and off? you should do this every day.
May 16, 2009 | Samsung Rant Cell Phone
Text message options
none. you can send an email to a phone number which by send to adx: xxxxxxxxxx@vtext.com (Xs' are the area code and phone number) the person will have to recieve two messages. there is a limit to the length of each sms(text) message (i think it is 164 characters)
May 07, 2009 | RIM BlackBerry Storm 9530 Smartphone
I cant get into my text messages on my BB Storm?
My name is Maureen Uwechia.
I had the same problem but I was able to find a way round it. I switched off the phone (blackberry storm), removed my sim, put the sim back after some minutes and put on the phone. Simple!! It worked.
Apr 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Downloading Text Messages on my Blackberry Storm
No, you can't do this. The BlackBerry stores your text messages in a database file that isn't compatible with anything other than itself. The only way to get your texts off of the device (in any kind of read-able format), is to forward them to another phone.
Mar 07, 2009 | RIM BlackBerry Storm 9530 Smartphone
Cannot receive messages
If your phone is a prepaid service and it has run out of credit at sometime recently this may be what is causing the trouble.
these services get stopped when there is no credit and are supposed to automatically turn on when credit is reapplied but sometimes it only half turns on so double check with your supplier that you are actually live to recieve messages
Oct 30, 2007 | Motorola Mobility RAZR V3
RIM BlackBerry Storm 9530 Smartphone Logo
103 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
