Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Convergance adjustment how do i align the three colors on convergance on a 60 inch phillips model#60pw9363/17f?
  • OBJ1264 Dec 24, 2007
    my tv shows alot of red coloring when watching it. The tv is about 10years
    old aside from the coloring everything thing else is ok. My model
    # is 6P5441 C103 Magnavox.
    President:
  • 4,402 Answers
Convergance amp ic bad
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 17, 2007
Phillips 60p8341 60 inch. can not adjust sharpness shows in 3d Color is fine just sharpness is bad.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 13, 2011 | Philips 60P8341 60" Rear Projection...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Bad color; everyone and everything is very orange
contact the store you bought it from. They will help you or refund you
Mar 07, 2010 | Philips Magnavox 9P6034C 60" Rear...
I have a Phillips rear projection 60 color lamps off focus
You can't adjust this. Your convergence amplifiers are bad and must be replaced. $250-$350 by repair shop.
Jul 08, 2009 | Televison & Video
Converge colors?
If the colors look 3D or if you can't adjust the blue or red convergence the convergence chips and resistors should be replaced. You can get a repair kit and photo instuction guide for this exact model from www.TvRepairKits.com. Hope this helps
Nov 15, 2008 | Philips 9P5034C 50" Rear Projection...
I have A 60 philips projection tv with triple picture
Don't adjust anything from the rear of the set unless you are a TV repair tech. It can get ugly real quick.
Try adjusting the convergence using your remote...Pull up the settings menu - goto picture - convergence - etc....See if you can adjust the color alignment back to normal. If not your convergence chips are most likely going out.
Nov 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
I have a phillips 60 inch projection tv double picture
Yes its the convergence ICs. You will need ywo STK392-120 ICs and about six of the 6.8 ohm 1watt metal resistors to repair the issue. You can get replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can easially do the repair yourself and save about 400.00. Here is the link.
http://servicemanuals.vstore.ca/
Jul 10, 2008 | Philips 60PP9202 60" Rear Projection...
Projection red is above other colors
Look in your menu for something called "horizontal static convergence" or just "convergence". Adjusting this will align all three tubes electronically. If physical adjustment is needed, then you have to do this manually inside the Tv. keever
Dec 09, 2007 | Mitsubishi WS-65908 TV
Convergence
it sounds like you have a problem with the IC's. 300-400 is an average price for replacement and convergence
Oct 26, 2007 | Philips Magnavox 9P6034C 60" Rear...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
282 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
