Question about Dell 1703FPt 17" TFT LCD Flat Panel Monitor
No Power plug in to power and nothing happens...registers having no power.
  • 138 Answers
Ok I got the same problem. And this is the way how to examine where the problem is. First try this monitor with another computer and power cord. If still the problem, you have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 07, 2008
Product code scanner (royal 9155SC cash register) not working
You might need to re-enter bar codes. Power failure might have deleted them
Jul 10, 2013 | Computers & Internet
When plugged in to mains nothing happens
plugged into mains as in plugged into power in wall? since we don't have a model number can you check to see if there's a power switch or button on the back of that drive?
May 21, 2012 | Computers & Internet
My lexmark s405 printer do not turn on
If you are encountering power problems with your printer, please go through the following checklist:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Jan 16, 2012 | Lexmark Interpret S405 Wireless All-in-One...
What happens to the memory when the register is unplugged?
If the onboard battery is good, nothing. There's a battery on the main board of the cash register that's designed keep the memory when power is interrupted.
Mar 03, 2011 | Royal Alpha8100ml 3000 Plu Electronic Cash...
My xbox 360 was on top of my TV aswell as my DVD player help!!
It is possible that something happened to the AC Adapter. If you have a friend that has an AC Adapter then you can try his to see if it works. Note it possible for something to be wrong with the system its self but it look fine.
Let me know if you have any more problems or questions
May 30, 2010 | Microsoft Xbox 360 Console
Casio TE2200 register with no power
It may have had a lock up. See if there is a tiny button next to the ports (sockets) on the side (probably under a flap). Leave key in REG mode with power on. Press tiny button for 2 seconds. Let go. If machine powers up, then it has had a lock up. DO NOT PUSH ANYTHING IF MACHINE COMES BACK ON OR YOU MAY LOSE ALL PROGRAMMING. Message me straight back and I'll tell you what to do next.
Feb 17, 2010 | Casio Parts Cash Register PC Desktop
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Philips dect245 searching problem
1. try to reset handset. try sw reset in the manual .
2. try to clear the base. unplug power cord, press and hold "page " key , and plug the power cord , after 5 to 6 second release page key.
3. Register again.
4. If there is still searching , open the base and handset, to check ,if the antenna is broken or not.
Jul 30, 2008 | Philips DECT 2252S Cordless Phone
Dell 1703FPt 17" TFT LCD Flat Panel Monitor Logo
Alun Cox
