Question about Hamilton Beach BrewStation 47224 Coffee Maker
Machine drips Maker won't stop drioping. Not a lot but annoying.
  • 1 more comment
  • hdtripper Jan 04, 2008
    I have the same problem of dripping. I tried just cleaning seal with cotton swab and water. Still drips.
  • jabby71 Apr 28, 2008
    I have removed the seal, flushed with water, cleaned the seal and reinstalled.....leaking continues.
  • kbmuncey Nov 17, 2008
    I have the same problem, I also cleaned it out and replaced a new seal. Still leaks. I took the screws out from underneath and removed the inner liner. I found the problem, The little part that the seal is attached to is broken. I need to find a new part.
  • 515 Answers
Try to replace the coffee dispenser valve assembly.
Posted on Jul 17, 2008
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Won't even turn on. Was flashing cup size lights on left & right and I turned it off and later tried to turn it on and it won't turn on.
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 13, 2011 | Keurig B100 Coffee Maker
My keurig won't even turn on. We unplugged and replugged but still nothing. The outlet does work, so don't know what to do. Is there a fuse or something simple that I could try. The Keurig is about...
heatman101
Aug 13, 2011 | Keurig B60 Coffee Maker
The machine won't turn on at all. Tried t in several functioning outlets and it won't power up. Only 6 months old. Keurig B60
heatman101
Aug 11, 2011 | Keurig B60 Coffee Maker
Morning We have a Keurig coffee maker but I don't see a model number. The machine won't turn on
heatman101
Jul 22, 2011 | Keurig B60 Coffee Maker
Coffee maker won't turn on.
heatman101
Jun 25, 2011 | Keurig Elite B40 Coffee Maker
My machine won't turn on at all
heatman101
May 30, 2011 | Keurig B70 Coffee Maker
My keurig won't heat up and the switch at the back won't go on or of
heatman101
May 26, 2011 | Keurig B70 Coffee Maker
Doesn't drip through. Don't know where the coffee water went to?
When setting up a new machine, it requires 2 full decanters of water to be poured into the machine. After you have done this, then you plug the machine in and turn on the vacation switch on the side of the machine. After 15 min, then you will pour in 4-10 cups of water and it will force out the hot water from the tank in the back and brew the coffee. If this doesn't correct the problem, then please call customer service with the model and date code.
Sep 11, 2009 | Bunn NHB Coffee Maker
How do you stop ice dripping
There is a water valve ( usually behind fridge in-line with tubing for water ), the valve is activated and releases water to fill cube tray. Does yours continue to fill or is it just overfilling a little too much and then stopping? You could try doing a search for schematics or diagrams for your make/model on Google for more info on how to adjust if it can be adjusted. Good Luck. If you are only getting a little bit of water in the ice pan and its just an annoyance, you could look for a plastic grid material that you could cut to fit into bottom of pan to keep ice from sitting in water. Then just empty water every so often.
Jul 02, 2008 | Refrigerators
Hamilton Beach BrewStation 47224 Coffee Maker Logo
73 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Marvin
Marvin
jason
80stech
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
