Question about Kenmore 53552 / 53554 / 53559
Kenmore 53552202 After a 3 day power outage my refrigerator came back on normally except the compressor did not start. I removed the back cover and listened. The start relay clicks on and off a few seconds later. The compressor does not start. If left on after a while the compressor gets hot.
  • 410 Answers
The relay is bad. get pt#8201786 and replace it according to the instructions in the box and your all done. this is a very easy repair. cost for the relay should be less than 60 bucks.
Posted on Dec 15, 2007
Why doesn't my Kenmore Refrigerator/Freezer freeze food?
The compressor could be failing, especially if it was running when the power outage occurred.
Jul 15, 2014 | Kenmore Refrigerators
Kenmore Coldspot 25ssa. After power outage the refrigerator trips breakers and GFCI
Either the compressor or the start device on the compressor is shorted out. More than likely the compressor, hate being the bearer of bad news
Jun 07, 2012 | Kenmore Refrigerators
. kenmore side by side blows warm air, after
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jul 30, 2011 | Kenmore Side by Side Refrigerator
Fridge stopped working after a power outage. When the power came back on everything seemed to work fine but the compressor is not running. If we unplug it and plug it back in the compressor works for...
Yup, I think you are right...
.there are many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 29, 2010 | Jenn-Air JCD2295HES Side by Side...
Our refrigerator started not being cold
your rtc or contactor on the compressor body needs replacement
Jan 01, 2010 | Maytag Performa PAV2200
My refidgorater clunks when it shuts off.
Good day,
If the noise is coming from the bottom rear, then it would be a problem with the compressor.
Remove the back cover, and listen while someone turns the machine off. You should be able to verify it's the compressor.
If that's the item, it means a centering spring internal to the compressor has failed.
There is no solution to that problem, except replacing the compressor.
If the machine is under 5 years old, that problem is under factory warranty, and would be free to you. If not you have a pricey problem.
If the cooling is still normal, then be aware that the compressor may run a long time in that condition.
P.S. Replace the back cover when done. It's important for proper ducting of the air over the condenser.
Dec 17, 2009 | Kenmore Refrigerators
I had a power outage for approx 1 1/2 hours. Now the freezer and
Ok, I need you to feel the compressor top to see if warm or too hot to hold your hand on. You may have a problem with the start relay or start capacitor. You may need to remove the cover on the rear of refrigerator and unplug before sticking your hands inside. Your outage may have been a surge and took out the start capacitor. Either way I will need to know what to find to assist you better. Look for the model number of your admiral also so I can look over you refrigerator parts to get a better view what we're working with. I be around here most of the day waiting for you to answer, Thanks, Sea Breeze
Aug 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
My model rs2555sl samsung fridge does not start up after power outage.
Samsung RS2555Sl suddenly stoped working once the power is switched off, If switched on again, only the Ice making sensor light flickers. If both Pwercool and power freeze buttons are pressed for 12 seconds it stars and running normally. Will it automatically start working if I change the Ice making sensor?
Jul 10, 2009 | Samsung RS2578BB Side by Side Refrigerator
Resetting my refrigerator
It is possible that there is no reset button.
Power outages or spikes usually affect the compressor which provides the refridgeration. It is possible that it may have got damaged. The spike is where the power have gone off but come back on too quickly causing. Spikes usually affect motors, pumps and compressors.
Sep 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Compressor Relay
remove toe cover from front of refrgerator and clean the condeser coil, if the condensor coil is block that is the cause for the start relay to have failed
Jun 17, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore 53552 / 53554 / 53559 Logo
117 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
