FixYa.com
Tags:
Microsoft Windows XP Professional for PC
D:\ application can not run in Win32 mode (by 99 users)
posted by buddybudz on Dec 15, 2007
after i right click the c or d icon of the hard disk, it states that the c: application cannot run in win32 mode
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
98 Other Users Have The Same Problem
Comment by mukesh57, posted on Jul 24, 2008
Comment by pimon, posted on Jul 21, 2008
I can't install some softwares cos i m running the win32 mode!!! i have no idea about it.
also i have to start the service of dhcp client every time i start my pc it doesn' go automatically.
does someone have an idea how it can be solved?
thanks in advance
all answers are appreciated
Comment by ananad, posted on Jul 08, 2008
how repair win32 files problme my problme is con not open drive win32 mode
Comment by ayush123, posted on Jul 06, 2008
When I Double click on the D Drive and E Drive, I get a window stating "The D:\ application cannot be run in Win32 mode." ; "The E:\ application cannot be run in Win32 mode." SOLVE ITTTTTTT!!
Comment by Guest, posted on Jul 04, 2008
when i click on my c drive the it show same error
Best Solution
posted on Dec 15, 2007
FixYa! (100)
bigbiggs
Rank:Wiz Wiz
Rating: 84%, 169 votes
R U using windows explorer or a program? Have you checked the compatibility of the program? are U running vista or XP?
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 04, 2008
FixYa! (100)
chandoo2099
Rank:Apprentice Apprentice
Rating: 96%, 34 votes
please help me my drive e shows e: application cannot run in win32 mode
Solution #3
posted on Jan 10, 2008
FixYa! (100)
jLmsm
Rating: 95%, 38 votes
To correct and solve this error, follow this steps:
1. Run Task Manager (Ctrl-Alt-Del or right click on Taskbar)
2. Stop wscript.exe process if available by highlighting the process name and clicking End Process.
3. Then terminate explorer.exe process.
4. In Task Manager, click on File -> New Task (Run…).
5. Type “cmd” (without quotes) into the Open text box and click OK.
6. Type the following command one by one followed by hitting Enter key:
del c:\autorun.* /f /s /q /a
del d:\autorun.* /f /s /q /a
del e:\autorun.* /f /s /q /a
c, d, e each represents drive letters on Windows system. If there are more drives or partitions available, continue to command by altering to other drive letter. Note that you must also clean the autorun files from USB flash drive or portable hard disk as the external drive may also be infected.
7. In Task Manager, click on File -> New Task (Run…).
8. Type “regedit” (without quotes) into the Open text box and click OK.
9. Navigate to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
10. Check if the value name and value data for the key is correct (the value data of userint.exe include the path which may be different than C drive, which is also valid, note also the comma which is also needed):
“Userinit”=”C:\WINDOWS\system32\userinit.exe,”
If the value is incorrent, modify it to the valid value data.
Solution #4
posted on Jan 02, 2008
FixYa! (100)
McIndia
Rank:Guru Guru
Rating: 89%, 135 votes
I dont know if you people solved the problem if you still have the problem post back, I will be glad to help you.
Comment by McIndia, posted on Jan 03, 2008
Did you solve the problem
congrats.
Solution #5
posted on Jan 25, 2008
FixYa! (100)
wellirp
Rank:Master Master
Rating: 92%, 9 votes
You have a known virus try downloading antivir from http://www.avira.com
Solution #6
posted on Jan 27, 2008
FixYa! (100)
louis_it
Rating: 92%, 16 votes
ThaaaaaanX jLsms, it's done.
At the same time i'd like to add a word of caution to that method . Please avoid /s in that code. Else all autorun.XXX files will be deleated. for me , autorun files in my "d drive" deleted. i quickly pressed Ctrl + C and stopped that command. ( i had a lot of software backups in my d drive )
also in command prompt (cmd), doskey command will help us to reduce some keystrokes .
i did,t find wscript in Taskmanager>Processes ( ie Ctrl + Alt + Del)
The method i followed is this
  1. Pressed Ctrl + Alt + Del
  2. Killed Explorer.exe
  3. Made run CMD
  4. pressed doskey ( it maynot be in some dosshells, if so just skip it)
  5. Entered cd\ ( to get in to the root of c . ie c:\ )
  6. Entered del autorun.* /f /a ( f=forced and a=archive )
(---- i think the other two ( /s = subfolders and /q = quite ) are not essential. More over that /s made some mess in my case )
Once again a agreat ThaaaaaanX to jLsms and to ixya.com
PS -
I've just recovered from a virus funny ust scandav.avi.exe . if anyone facing the same damn, pls ask me , its a simple process from dos ( but a hell from windows ). Cheers!!!
Solution #7
posted on Jul 03, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
i tried this method its working thank you
Solution #8
posted on Jun 25, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
jlmsm appreciate u man.U did great.
Lot of thanks
Jashi
jashimbv@gmail.com
Solution #9
posted on Jun 19, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
solution for funny ust ...exe
download avg anti virus from filehippo.com and go for complete computer sacn. it will remove that virus.
next u might face another problem like application canot run in win 32 mode.
for that follow the step wat stared above
Solution #10
posted on Jun 18, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
please someone help me ,how to remove FUNNY UST SCANDAV.AVI.EXE.........IT KEEPS ON ENtering and crashing !please.....
Solution #11
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Can you Help with these Operating Systems problems?
Operating Systems
microphone not working
my system is saying there is no... Answer This...
E/archive RUNDELL
como lo arreglo es un programa... Answer This...
IE7 Kernal32.dll error problem
The problem occured after the... Answer This...
warcraft 3 frozen throne
Hello, I just got warcraft and... Answer This...
Wireshark
http://www.wireshark.org/ Im... Answer This...
98 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jul 01, 2008
my all drives getting the same problem
Comment by murty143, posted on Jun 29, 2008
When I double click on my C ,D,E or F it shows C:\ is not a valid Win32 application. what can i do
Comment by pappufunny, posted on Jun 26, 2008
hai i am pappu my drives are also giving same error
Comment by Guest, posted on Jun 20, 2008
can't access
d:\ apd:\ application can not run in Win32 mode problemplication can not run in Win32 mode problem
Comment by successjohn4, posted on Jun 18, 2008
c:\ application can not run in Win32 mode
Comment by Guest, posted on Jun 15, 2008
not able to open D:\ , E:\ or F:\
Comment by ary4you, posted on Jun 11, 2008
d:\ application can not run in Win32 mode problem, and notify you when a new solution is offered.
Comment by Guest, posted on Jun 11, 2008
on double clik drive say is not a valid win32 application
Comment by toton1111, posted on Jun 11, 2008
The D:\application cannot be run win32 mode.
The D:\application cannot be run win32 mode same problem.
cannot be run in win32 mode
Comment by haque78, posted on Jun 05, 2008
i received this error
the c:\ application can not run in win32 mode
Comment by Guest, posted on Jun 05, 2008
i have the same problem like after uploading the photoes into my ipod in windows vista and when i open it in winxp its giving the same problem. plz provide me the solution...
Comment by Guest, posted on Jun 01, 2008
application cannot be run wid 32 mode
Comment by Guest, posted on May 27, 2008
the application can not be run win32 mode. what should i do.
Comment by invents, posted on May 02, 2008
same problem as mentioned by all
Comment by Guest, posted on Apr 29, 2008
Comment by sidhartha ki, posted on Apr 28, 2008
i have the same problem in my acer aspire4520 laptop,what should i do to resolve this problem
Comment by Guest, posted on Apr 28, 2008
Comment by san_world, posted on Apr 25, 2008
please post a comment to buddybudz's d:\ application can not run in Win32 mode problem
please !
Comment by kom khatri, posted on Apr 23, 2008
When I open the C, D, E drive then a message displays: "Can't open the win32 application." How can I solve this problem?
Comment by pedope, posted on Apr 18, 2008
the c application can not be run on win32 mode
Comment by sollu, posted on Apr 17, 2008
Rgt now i am using command prompt to resolve the prolem
Comment by Guest, posted on Apr 12, 2008
unable to open pen drive with this massage.
I am Getting the foll error when I want to open the E:drive: "The E:\application cannot be run in Win32 mode "
Comment by Guest, posted on Apr 05, 2008
Comment by wajdi, posted on Apr 04, 2008
I Have a problem when i opened a drive for example c: or d: drive a box is opened which tells me that this application can not run in win32 mode
Comment by Guest, posted on Apr 03, 2008
Comment by Guest, posted on Mar 29, 2008
i have aproblem with my hard disk,when i open these by double click"D:\ app can not run in win 32mode."
Comment by aukreddy, posted on Mar 20, 2008
i face d same prob ! any of d drives aret openin!
Comment by tejabhai, posted on Mar 19, 2008
C:\ application can not run in Win32 mode
Comment by Guest, posted on Mar 18, 2008
cannot run application in Win32 mode
Comment by weby, posted on Mar 17, 2008
Comment by Guest, posted on Mar 12, 2008
Comment by fahvir, posted on Mar 08, 2008
d:\ application cannot be run in win32 mode.
Comment by fgkm, posted on Mar 07, 2008
Could not find any solutions..
so far opening by useing explorer.exe
fgkm
Comment by Guest, posted on Mar 07, 2008
hi,
when i click drive D/E/F it is not oped it generate the message
Comment by Guest, posted on Mar 01, 2008
The c:\ application cannot run in Win32 mode
Comment by yanbert, posted on Feb 28, 2008
the application cannot be run in win32 mode
Comment by Guest, posted on Feb 27, 2008
reg.exe add "HKCR\Drive\shell" /ve /d "none" /f
regsvr32 shell32.dll
Comment by Nemesis123, posted on Feb 27, 2008
Ive da same problem too!!
Comment by nabin, posted on Feb 22, 2008
I have a winxp prof on my laptop. now i am having the same problems.
Comment by Guest, posted on Feb 21, 2008
Comment by sanjaybk, posted on Feb 20, 2008
go to task manager click on file an click on new task(run..)
and type cmd
and type del autorun.*/f/s/p/a/
Comment by khan021, posted on Feb 17, 2008
Dear,
I don't have problem in this but i see this problem has came from many users in my organization still i am trying to solve this thing but solution for this is not found please let me know how can fix this?
Comment by coolgeth, posted on Feb 17, 2008
i do have rthe same problem
Comment by Guest, posted on Feb 15, 2008
Comment by umermasood, posted on Feb 14, 2008
F:\application cannot run in win32
Comment by milantamang, posted on Feb 14, 2008
when im click on the C: or D: or E: drive ...it says...d:\ application can not run in Win 32 mode...how can i solve it..
Comment by Poohmec, posted on Feb 12, 2008
I cannot open my local drive and a dialog will pop up says that C:\windows cannot open the 32 mode. What would i do to open my drive?
Comment by Guest, posted on Feb 12, 2008
i cannot open my local drive and message will pop up says that c:\cannot open win32 mode.What would i do to be able to open my local drive?
I got the message while trying to open a tcl file.
message: Cannot run c:\tcl\demos\Expect\remotels.tcl in Win32 mode.
Comment by Guest, posted on Feb 09, 2008
how to solve this problem 'application cannot be run in win32 mode'
Comment by Guest, posted on Feb 07, 2008
same probs
Comment by Guest, posted on Feb 06, 2008
The application cannot be run in win32...
Comment by rea1480, posted on Feb 02, 2008
" THE C:/ APPLICATION CONNOT RUN IN WIN32 MODE" thats the error i always read when i open my drive c. I reformat my pc already but when i open the drive c, still the problem exist. I download...superantispyware..ad aware..but it doesnt work. I downloded yahoo messenger and everything that my pc lost when i reformat it, except from skype which the system wont allow because it said that...skype.exe is not a valid win32 application. I really dnt know what to do...am working on it now...i am badly needed your help....
Thank you!
Comment by Guest, posted on Jan 26, 2008
C:\ application can not run in Win32 mode problem
same problem please help
Comment by Guest, posted on Jan 22, 2008
Comment by Guest, posted on Jan 21, 2008
drive c, d and h can not be run in win32 mode
Comment by BS_Mandal, posted on Jan 19, 2008
c:\ application can not run in Win32. I have received the same message for all of my four drives when I click on them.
Comment by Guest, posted on Jan 18, 2008
I have the same problem. application can not run in Win32 mode. Please suggest a solution.
Comment by skvydya, posted on Jan 11, 2008
when i open D/E/F drives "Applicaion cannot be run in win32 mode" messege comming on the screen pls. any one give solution to me my E-mail sant_vaidya@yahoo.com
Comment by Shridhar, posted on Jan 09, 2008
My PC is with Windows XP Professional. When I try to open D/E/F drives it shows THIS APPLICATION CAN NOT OPEN WITH WIN 32 MODE
Comment by naseer123, posted on Jan 09, 2008
when i open any the drive it gives the following error
Kindly give solution when at as soon as found.
Comment by tagore, posted on Jan 08, 2008
Comment by Guest, posted on Jan 08, 2008
Comment by Guest, posted on Jan 07, 2008
Me too !!
Comment by kalyan000, posted on Jan 06, 2008
i too have the sane problem of not accesing my drives
please help me
Comment by Guest, posted on Jan 06, 2008
d:\ application can not run in Win32 mode... yeh same problem after i removed some viruses...
Comment by zaaki, posted on Jan 04, 2008
when i open my drive error can not open win32 mode
Comment by hmkhan, posted on Jan 04, 2008
Comment by Guest, posted on Jan 03, 2008
getting the same arror for all drives. it started after i tried to remove Funny UST scandal.avi.exe virus, smss.exe and killer.exe. use symantec antivirus to fix the problem. virus seems to be gone but stuck with this problem.
Comment by IDSP, posted on Jan 02, 2008
when i try to open the C,D or E drive of my hard disk, it displays an error
"The application cannot be run in win32 mode"..what should i do in such a case?
Comment by Guest, posted on Jan 02, 2008
same prob
Comment by ushakiran, posted on Dec 31, 2007
when iam clicking on any icons in my harddisk. it is displaying d:\ application can not run in Win32 mode.
Comment by Guest, posted on Dec 31, 2007
Comment by manoj2008, posted on Dec 29, 2007
I receive following massage
When I click on Drive D, E and F of my Hard Dribve I get massage
Pl help
Comment by Guest, posted on Dec 28, 2007
Comment by Guest, posted on Dec 27, 2007
please tell me how to solve this problem
have the same problem..no solution yet?
Comment by Guest, posted on Dec 26, 2007
i m unable to open my d,e & f drives ...........
an error is displayed ....... application cannot be run in win 32 mode.............
Comment by Guest, posted on Dec 24, 2007
Comment by Guest, posted on Dec 22, 2007
when i click the drive the errors come d:\application can not run in win32 mode plz solve my problem
Comment by subbit2006, posted on Dec 21, 2007
yes i have the same problem
Comment by Guest, posted on Dec 21, 2007
when i click on my D drive error disply d:\ application can not run in win32 mode..
Do u have any solution for the same problem or you just keep to tel us what the problem is
Comment by Guest, posted on Dec 18, 2007
yes i have same problem d:\ application cannot be run in win32 mode. what i do plz guide me
yes i have same priblem application cannot be run in win32 mode
Comment by Guest, posted on Dec 16, 2007
Repair Service
Find Operating System Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
