Question about Hotpoint First Edition FEW12 Front Load Washer
Changing bearing on hotpoint FEW12??
Trying to check/change drum bearings on my machine. The main problem is tthe sides and back is 1 piece, therefore the back isnt removerable as with older models.
The problem is how can I get access to the bearing?
And how is it removed ?
thanks MMR
  • Anonymous Mar 14, 2014
    is it possible to change the drum bearings.ive tried to remove the top after taking the two back fixing screws but the top doesn't want come off.
  • 139 Answers
Welll its a long job.
first remove the top
then the front control panel.
disconnect any wires connected to the circuit board.
then remove the front panel with the door intact. to do this you must unscrew the the screws in the top and bottom and remove the screws for the door inter lock as well as undue the door gasket from the panel.
Then you got to remove the concrete weights. and pull the pegs in the legs from the drum side.
Then you got to dissconect the drainage at the bottom of the drum from the pump
remove the wires from the solenoid and disconnect the pressure switch from the small plastic tube.
undue the tubing from the soap draw to the drum
remove the clips near the springs.
undue the front metal panel which the board was connected to and remove the drum
if you need anymore help dont be afraid to ask.
Posted on Dec 16, 2007
Does the outer drum on a hotpoint WT540
All outer tubs on most Washing Machines these days are sealed.
Therefore you cannot split the tub to get inside and change the bearings. instead you have to change the whole tub assembly as a complete unit. Not an easy job.
Oct 27, 2014 | Hotpoint Washing Machines
It's a hotpoint wf541g washer, I've read the
You can buy bearings but the only way to confirm the exact sizes used is to dismantle the machine and then you will be able to identify the ones used, The main reason they suggest a new drum is sometimes the bearings will not come out or go in easily and can cause the drum to crack which means you would need another drum if this happens.
Mar 04, 2012 | Hotpoint Washing Machines
Sounds like bearings are shot, makes loud noises on fast spin. is it a big job to change bearings?
If you believe it is a bearing then the answer is no unless you don't have the proper tools. Second of all did you check if your machine is mis-align and rubbing to make that noise. Just a suggestion before you tear into the machine. Good Luck
Jan 09, 2011 | Hotpoint First Edition FEW12 Front Load...
Hotpoint WT540 Bearing Change. I have got the drum out but I am having problems spliting the drum. Is it bonded or are there any tricks I can use to split the drum without destroying it
If there are no visible screws or other obvious means of the 2 drum halves being joined together, then it is not possible to change the bearings, as it is a one piece drum.
Current models are one piece, earlier models had screws securing the drum halves together,
Hope this helps..
Jan 11, 2010 | Hotpoint First Edition FEW10P Front Load...
Hotpoint WMA54 - in middle of attempting to replace the drum bearings. I've split the drum apart and am attempting to remove the existing bearings and spider; however, I'm unable to separate/unscrew the...
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Jan 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine very noisy on spin
For all your parts visit our sitehttp://www.apart4u.co.uk
utube.png You-Tube video "kG5HWQ0x2s0" placeholder (do not delete) utube.png
Oct 21, 2009 | Hotpoint First Edition FEW12 Front Load...
Very noisey on spin cycle
Almost certainly the main drum bearings have failed.
Jun 25, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint FEW12 washing machine chews up clothes
If you check the door sal and there is any play in it then it needs replacing. Mine had two saggy indent bits and needed changing..no more ripped clothes
Apr 10, 2009 | Hotpoint First Edition FEW12 Front Load...
Machine banging when in fast spin
if the noise is coming from inside the drum then it will be the bear ings if this machine is less than 3years old then this is what bust hotpoint they changed the bearing setup and put a spring on it which its the spring that is the complete failure u need to take the complete drum out strip this put the new bearing set in but without the spring this wil put at least 2-3years on the bearings its a big job and costs about £120 to fix u r accually better off buying a completely different washer no good are hotpoints anymore m8
Jan 26, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint first edition wma 11 drum bearings removal
Hey kevin that outer cone of the front bearing is a mission im telling ya...
But from experience ive found that by cleaning around it ( i use a metal brush on a drill ) and using wd40 and letting it soak in for a few hours its makes like a lot easier,,
I use a bolster with an end similar to a crow bar to just get inbetween the tiny gap and a very big lump hammer to know out the cone.... Best way knocking it from side to side ie bottom the turn the back half of the drum round and knock the top then the sides,,
hope this helps....
cheers mate..
Jan 10, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint First Edition FEW12 Front Load Washer Logo
625 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
