Question about Andrea NC-7100 Consumer Headset
Vista inspiron 1720 was working fine?
My computer reconises the device but it won pick up signal any more?
I think it may be a faulty head set ?
the voice wen it works keeps droping out and sound on the head set was droping out should I re turn it for a refund?
0 characters
1 Points
My recorder isnt working
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution. Thank you for choosing FixYa to solve your problem. The recording feature of your electronic device isn't working properly? You should try turning the volume up on the microphone so it can pick up your voice clearer when talking. If you still can't playback any recordings, check the volume settings of your device on your computer. This is located in the Control Panel (Windows) and the System Preferences (MAC OS) applications of your computer. Go into your operating system's preferences and increase the microphone volume. You may also need to select your headset device as the default recording device (Windows) or the Output Device for recording (MAC OS). If you want my opinion, I think your headset device is not set as the default recording device. If you don't have a headset as the default recording device or output recording device, you can turn the volume up to the maximum setting and you still won't be able to record anything because the computer has another device (if any microphones are installed in the PC) as its default or output recording device. That's why it's important to check your system preferences for a headset to make sure it has the proper settings. I hope you understand this solution and that you can record audio on your headset. Reply back if you need step-by-step instructions.
Jul 01, 2011 | Logitech ClearChat Stereo Headset Headset
I have life chat lx-3000 headset that was working fine. I use these on gamer vent server. Recently other players were unable to hear and mentioned they heard static then not me. I recently updated my sound...
My guess it's something in the cabling of this device I think it is cheaper to buy a new headset with the same quality. I think that that best solves your problem.
Oct 14, 2010 | Microsoft LifeChatâ„¢ LX-3000 Headset
My microphone dosnt pick up any sound
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
I am using Vista 32-bit, Logitech Clear Chat Style
Hope can help
Aug 24, 2009 | Logitech Internet Chat Consumer Headset
H350 will not work on pc
there is no need for the driver
just follow this
ok here u go first turn on the bluetooth func in ur laptop, now while ur bluetooth haedset is off press the power centre big button for like 10 sec until the blue light stays on continously not blinking position ok then search for bluetooth devices in the bluetooth software there is an icon in the taskbar bluetooth right click and take properties search for blutooth devices there ur headset will come up like motorola h550 select it then it will ask u for pairing code input 0000 and press ok ur device is now connected u will see the blue light which was continous b4 now blinking it means ur haedset is connected , u have to complete this process in almost 1 min bcoz there is a timeout for this process , now try the sound settings in the taskbar or play music u will hear it in ur headset
pls rate me FIXYA for this
Feb 22, 2009 | Motorola Mobility H350 Wireless Headset
Computer headset problems
It sounds like something in the control panel on your computer, Go into the sound settings and pick your device.
Below is the link for Explorer 300 Series User's Guide.
Plantronics Explorer 300 Series User's Guide
Good luck from Headsets Direct!
Jan 17, 2009 | Plantronics Explorer 330 Headset
Philips SHM3300 Headset
try to unplug your main speakers and replace the head phone, if it still doesn't produce any sound, then you may replace your head phone.
Oct 30, 2008 | Philips SHM3300 Headset
My H700 Motorola Bluetooth Headset
i just want to know how to get it to work in the first place... got a new phone and need to set it up but i lost my directions. how do i just get it to work
Oct 01, 2008 | Motorola Mobility H700 Wireless Headset
Logitech clearchat pro headset
hello guys,
you have to update your audio card drives and vista updates should be upto date. then follow following options and you could find the solution there.
Jan 15, 2008 | Logitech ClearChat Stereo Headset Headset
Head set problem with vista
you will need to go into the sound manager in control panel and make sure that the external mic is enabled as the default use and ensure in the sound settings that the mic is not muted, this is normally done by right clicking the speaker icon in the taskbar and selecting options and see if the mic is muted or not in the properties
May 26, 2007 | Logitech Premium Stereo Consumer Headset
Open Questions:
Andrea NC-7100 Consumer Headset Logo
Top Andrea Headsets Experts
Brian Sullivan
Brian Sullivan
Are you an Andrea Headset Expert? Answer questions, earn points and help others
