Home | Yamaha | YSP-800 System | Playing stage piano usi...
Yamaha YSP-800 System
Problem for Yamaha YSP-800 System
Playing stage piano using YSP-800
By Japi on Dec 15, 2007
I have a Yamaha CP33 stage piano. It is a good instrument, but does not come with speakers, so I invested in a used YSP-800 sound bar. The piano and the speaker system share a sleek and sober style and keeps the installation and wire mess to a minimum. As expected, 30W (82W peak) is plenty for me and the response over the whole spectrum is good even if slightly limited in the lower range. My deception is that this speaker unit delays its output. I would say something in the range of 100-200ms. This really spoils the playing experience, especially with sounds with a sharp attack (like piano). I could not find in the user manual any indication to eliminate or at least reduce the annoying delay. Is there anything I can do? I don't even mind open the unit and doing some soldering as I cannot return it.
Comments:
Jan 06, 2008
- You are right about the setup options, but the delay cannot be fully eliminated. Even when you set it at 0ms, there is still a delay of about 150ms. I contacted Yamaha tech support and there is no work around. The delay is supposedly present on all the current YSP product line. YSP digital signal processing induce a delay that can only be increased using the setup options to match the delay of some "slow" TV sets. In an ordinary home theatre configuration the delay is imperceptible, but if you play games or music, it is another matter. So I've sold my YSP-800 and I bought an M-Audio LX4 2.1 system, which I should receive next Monday. The sound should be much better (an without a delay), but I will miss the YSP form factor.
Solution #1
posted on Jan 04, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
yes, you can tweek the delay.. take a look at the manual setup options.
Popular Solutions for Yamaha YSP-800 System
Questions and Unsolved Problems for Yamaha YSP-800 System
Do you recommend Yamaha YSP-800 System?
Answer
Answer
yamaha ysp-800 stuck on mute, volume indicator just flashes
Answer
The Yamaha YSP-800 will not turn on. There is no evidence of powering on at all. Plug and fuse are... (More)
Answer
sound distorsion interminent trouble...
Answer
i bought a ysp 900 which did not have the set up microphone or the remote. does anyone have the... (More)
Answer
this unit came on by itself in the middle of the night with full blast sound...scared us! No one... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Yamaha YSP-800 System:
Top Home Theater System Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Home Theater System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
