I have a problem with my HP Laserjet 3050. I changed the fuser Part smoothly. But when I went to...
(More)
I have a problem with my HP Laserjet 3050. I changed the fuser Part smoothly. But when I went to assemble all remaining parts, the plastic arm that is attached to the cover and allows the wheel that holds the toner, was released. I tried to put that piece of plastic back in place, following service manual, but it works just the opposite, ie when I open the cover, the wheel that holds toner remain in its position, and when I close it, wheel is released. I've reviewing it, but the part that moves the "clutch" and made to remove or put the wheel that holds the toner, seems fine. Any suggestions? THANK YOU SO MUCH.
fax wont dial out. cant send fax.I dial and load the papers, one it takes in the first paper it says...
(More)
fax wont dial out. cant send fax.I dial and load the papers, one it takes in the first paper it says the memory i full. help
