Question about Pentax ZX-50 35mm SLR Camera
Camera inoperable Camera probably has less than an hour of use on it. It set in the closet for a couple of years then when tried to use the display only showed a flashing E with the battery indicator. Put in all new batteries and the E is still all I get. The camera is 8 or 9 years old and the number on the bottom of the camera is 8119701.
  • 3 Answers
According to the manual found here:
http://www.pentaximaging.com/files/manual/ZX50.pdf
It says, "If the film is not loaded properly, 'E' on the LCD panel blinks, indicating that the film is not loaded properly. Open the back cover and load the film once again."
Posted on Feb 04, 2008
I found my old IRulu AL101 in my closet and i plugged it in but all its doing is showing a red light
let it rest in the charger overnight, the battery has become so low it needs a firm charge first to be able to work again might be working after charging it for 1 hour even but i would still let it charge overnight..:)
Jun 02, 2016 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
I have an intova IC12 digital camera. It will snap a picture and show on the display but not save to card?
Please save any images to your desktop that you want to keep. Access format function in camera's setup menu and format both SD card and internal camera memory to clear all data. After formatting, perform a sys reset that is also found in the setup menu. If your camera still cannot save images to the SD card after performing format and sys reset, then the card reader/writer is probably broken. Please contact us directly at 808-837-0074 if you have a sales receipt showing date of purchase 1 year or less which would qualify for warranty exchange under our 1 year warranty coverage.
Thank you
Apr 25, 2015 | Intova Ic12 Digital Camera
I can't figure out how to set the self timer from the manual on a canon powershot sx 110
For the SX 110 IS 9 mp camera: With the camera in picture taking mode, Hold the bottom of the roller dial down at the point closet to the timer icon. Hold it for a couple seconds, then the screen will display the timer settings. Select the setting you want and start taking pictures.
Jul 17, 2009 | Canon PowerShot SX110 IS Digital Camera
Setting the time..
Normal 0 this is how ive changed the time before, note that you dont see the number you type in.
Press FEATURE **8463 – Display shows PASSWORD:
Then type in 23646 (Note this number will not show on display)
The display will show hours.
Press CHANGE (or NEXT if you do not need to change the hour).
Enter the hour (00 to 23). If number is less than 13, the display shows AM.
Press CHANGE to select PM.
Press NEXT. The display shows minutes.
Press CHANGE (or NEXT if you do not need to change the minutes).
Enter the minutes (00 to 59).
Press NEXT. The display shows year.
Press CHANGE (or NEXT if you do not need to change the year).
Enter the last two digits of current year.
Press NEXT. The display shows month.
Press CHANGE (or NEXT if you do not need to change the month).
Enter the month (01 to 12).
Press NEXT. The display shows day.
Press CHANGE.
Enter the day of the month (10 to 31)
Press RLS (release) to exit.
Oct 27, 2008 | NorStar M7310 Corded Phone
Setting date & time on M7310
Normal 0 TIME CHANGE PROCEDURE: DONE FROM THE MAINPHONE
The display will shoe hours.
Press CHANGE.
let me know how you get on
Sep 15, 2008 | NorStar M7310 Corded Phone
EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Sep 02, 2008 | Sharp EL-1801P Calculator
Canon A620 No Picture
When your on a photo taking setting and your camera isn't picking up what your seeing...this isnt a problem.
simply press the "disp" button until your picture shows up and the extra features for that setting.
Aug 15, 2008 | Canon PowerShot A410 Digital Camera
Reset clockdue to power outage.
hi, this worked for me
Press CHANGE.
this has to be done fro the main phone system
hope it helps
Jul 09, 2008 | NorStar M7310 Corded Phone
Changing Time and Date
i had this problem a while ago, you have to set the time from the main phone
Press CHANGE.
Apr 16, 2008 | NorStar M7310 Corded Phone
Pentax ZX-50 35mm SLR Camera Logo
115 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
