Panasonic PT-53WX53G
Sound okay,No picture. Light squiggly line runs from top to bottom in center. Prior to failure I had to adjust convergence multiple times to bring words back into focus.
Comments:
Sep 23, 2009
- No, the line is in the center, it is blue/green in color and is only noticeable with low room light.Sep 24, 2009
- Any suggestions?Sep 25, 2009
- I will look at thtat and reply. ThanksSep 26, 2009
- Found c509 and removed (wes4743, 250v), no obvious damage but I will get new part. I noticed some discoloration to the pcb under R1510, R1511, R1514, R1518, & R1542 is that normal? They look as though they are expected to get hot, they are installed about 3/8" off the pcb, ceramic maybe 1/8th watt.Sep 26, 2009
- Can I clean the projection lenses with windex, or could you suggest a product that would be safe for use? ThanksSep 27, 2009
- Its been a while since I've looked at caps is a 4743 the same as a 474K? I have a 474K 2A but no voltage raiting it is slightly larger in size than the one I removed.Sep 28, 2009
- having a hard time finding a store that sells components in this area, might take a day or two but I will find one.Sep 28, 2009
- I need to clarify the cap value. Marked on the cap is 4743, I thought the second 4 would be the multiplier
4 = 10,000 pF (10 nF or 0.01 uF), which I think would make the cap a .47 uF. I just want to double check before I purchase and install. I am not familiar with a four digit value code. ThanksSep 29, 2009
- odered part at partstore.com, I will let you know the outcome once I've received the part and installed it. ThanksOct 02, 2009
- received part today, will not be able to install for a couple days, will post with results. ThanksOct 14, 2009
- Installed part and picture came back, there might still be a convergance problem but I will adj. converg. and watch for a couple days. If something else comes up I will post. Thank you very much for your time and advice this is a great website for the amature TV repairman.Oct 14, 2009
- sorry for the delay, PA archery season opened on Oct. 3rd
Clarification Request
Posted by SD Tech on Sep 29, 2009
part number for the cap is
ECWF2474JSR
Posted by SD Tech on Sep 28, 2009
The cap is a .047 @ 200 volts-----you can use a cap of the same value with at least a 200 volt rating or more.....
Posted by SD Tech on Sep 26, 2009
you can use windex but spray it on a paper towel and not directly on the lens. Yes those resistors do discolor the board and it is normal.
Posted by SD Tech on Sep 24, 2009
Locate C509 on the main board--it is brown and if it has a crack in its side--it is gone---sometimes it will look perfect and be bad---seen several of these sets with this trouble
Posted by SD Tech on Sep 23, 2009
is the line a unusual area towards the right side of the screen?
