Question about Honeywell Programmable Thermostat Heater
Honeywell therostat wiring help
Have issue with long delays and heat and air coming on together. Wired exactly what they told me to do. replacing old Honeywell mercury with new digital.
Wiring:
OLD-NEW
R-R
Y-Y
W-AUX
C-C
jumpered E and AUX
HELP?
  • elvin24 Jan 03, 2008
    i got a honeywell programmer model#rth6300b my heat dont stay on longer it turn off quick what i need to do
  • kozpg Jan 12, 2009
    i have a two wire 24 volt heat only system and just purchased a honeywell RTH 221B1000 thermostat. there are 5 places for wires , where do my two wire go?
    Habit-Forming:
  • 115 Answers
Don't assume the wires at the thermistate are correct.
I had similar and had to go all the way back to the heat/AC controller board. I found the colors weren't attached per spec so was fighting the origional installation at the new thermistat.
Also some digital won't control mutizones proerly
Posted on Dec 19, 2007
THERMOSTAT WILL NOT COME ON.
You may have missed the fuse. It will/should be part of the control board and has a 3 or 5 on it. You can jump R to G at the tstat by touching them two together. If you don't feel comfortable doing this then don't do it. G will bring on the fan only. And if it starts then you probably have a bad tstat. If not, then you have a short that damaged your 24volt transformer, or lost power to the whole unit. Check your breakers!
Mar 10, 2017 | Heating & Cooling
Outdoor AC unit runs for about 2 minutes after air handler shuts off
Hello, it is possible that the new thermostat has some type of time delay built in it. But typically this would shut of the outdoor unit first and then the air handler.
Jul 25, 2012 | Heating & Cooling
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Apr 21, 2010 | Honeywell Heating & Cooling
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
Ruud UBHC AC System - Provides no Aux Heat
Tried this on my unit today, and observed the same results, but got Aux Heat (with A setting), if the H (blue wire) connected to B terminal, as per instructions for my 6036 Ritetemp. However, in this case, when the set temp is reached, I hear the click, but HVAC still blows aux heat indefinitely.
I also have RUUD UBEA 17J10..., and replaced my old honeywell with 6036, and can't get heat pump working. Both of my units are 14 years old, so I'm thinking to replace them soon.
Jan 06, 2010 | Ruud UBHC Air Conditioner
Installing Honeywell RTH7000 - I have too many wires!
check to see if the B terminal is on the new t-stat if connect to it , but this terminal refers to heat pumps and is normally use to energize the reversing valve on the outside unit and not used on ac units , but normally the tag O/B is the same terminal on therostats
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Need to bypass therostat for residential furnace
To bypass a t-stat for heat connect te red, green, and white wire together
Oct 19, 2008 | Honeywell Heating & Cooling
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heat pump thermostat replacement
It sounds like your reversing valve energizes the opposite from how you wired it at the thermostat. Check the instructions.
Oct 28, 2007 | Honeywell Programmable Thermostat Heater
Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Oct 12, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
260 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
