Question about GE Dishwashers
Dishwasher timer does not move
I have a GE built-in dishwasher model number GSD3408K008. The timer dial does not move. Does it need to be replaced? If so can I replace it myself?
  • 49 Answers
SOURCE: Dishwasher not washing
sounds like the wash pump (wich recirculates the water during wash) has something stuck in the impelor or the wash pump motor is faulty. someone qualified would have to check this for you
Posted on Feb 19, 2008
SOURCE: Kenmore dishwasher limited edition model 665
Anyone know anything about heating elements, mine won't dry the dishes, thanks
Posted on Jul 18, 2008
  • 750 Answers
SOURCE: sticking programer dial
Hello zxnigel,
Welcome to fixya.
I'm Huuum at your service.
You said, The program timer on my dishwasher is sticking.
And you have to move the dial by hand as it is taking 3 hours to do the wash cycle
I think the timer needs to be replaced!
What brand an model is your machine?
And how old is your dishwasher?
Let me know this information, please.
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old Appliance
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your appliance,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your appliance is under warranty or less than four years old
paying for a repair makes sense.
Note that appliances under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your appliance is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new appliance.
Data also shows that it doesn't pay to fix a less-expensive applaince
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a appliances you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please remember to leave a rating before you sign off!
Thank You, HUUUM
Posted on Sep 30, 2008
SOURCE: How do I remove the top rack on the ge profile built-in dishwashe
Posted on Nov 30, 2008
  • 82 Answers
SOURCE: Dial Timer sticks between wash or rinse modes
Hello. Is the water getting hot? Usually the timer won't advance because it isn't getting a signal from the thermostat that is on the bottom of the tub, so it thinks that the water isn't hot enough to go through the rest of the cycle. That is if the water is hot. If it isn't hot then you may need a new heater. You may or may not need a new timer. Try the thermostat first because that is usually the thing that goes out and it is less expensive than the timer. You can order it from or .
Let me know if you need anymore help.
Posted on Dec 08, 2008
  • 734 Answers
SOURCE: Frigidaire Dishwasher won't start
hi there,
as u said that u have already replaced the timer u may also try the following:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Posted on Dec 10, 2008
0 characters
1 Points
Cycle dial doesn't advance automatically anymore. I saw some listed problems that sounded similar, but not exact. Washer will work in all cycles, but only when I watch and move the dial manually.
Hello & Welcome to FixYa
Its seems that the Timer is stuck, as everything else is working fine in the unit and the dial ust gets stuck and so won't complete the cycle so the problem is with the Timer motor going bad and needs replacement. Please get back to me if you have any other questions.
Dec 24, 2010 | Kenmore 15522 Built-in Dishwasher
Kenmore 17602 dishwasher. It is filling, but then
timer needs replacing.I am not sure of that model but if its the dial model thats the problem...the clock type timer fails at that setting...try a lighter or heavier selection on the dial.
Jul 20, 2010 | Kenmore 24 in. 17602 / 17604 / 17609...
Ge profile dishwasher runs for hours
HI, this will occur if there is a major control fault in the timer module or, main control board. Depending on you model, you will need to replace the timer or, control board in this case. this will fix this issue
Jul 15, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
Dial sticks in two places until dial is moved slightly
HI. this Timer mechanism will need ot be replaced soon. the timer motor is defective. this will continue to affect the performance of this unit. replace asap.
Jun 20, 2009 | Frigidaire 24 in. FDB750RCC Stainless...
Cycle Sticks unless I manually move it along
Ya, the mechanical timer/dial is the problem. The heating element just got stuck on as the timer stalled in that dry cycle.
May 03, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Cleaning Cycle not Starting
Please provide the model number and the approximate age of the dishwasher.
If this diswasher uses a turning dial to select the cycle, which turns as the dishwasher progresses, I strongly suspect that this timer has failed and needs replacement. Especially since the soap door never opens. Does the dishwasher drain during and at the end of the full cycle?
Mar 29, 2009 | GE Dishwashers
GE dishwasher
If you can move the timer manually, then check the power to the timer motor. If you have power to the motor, replace the motor
Dec 14, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
this is a sign of a defective timer mechanism. replacing the timer will fix this issue. Replace the timer/control model asap.
Nov 03, 2008 | Roper 24 in. RUD3000 Built-in Dishwasher
Dial not moving/not cycling through
If the dial won't rotate then you need to replace the timer.
Mar 30, 2008 | GE 24 in. GSD2000Z Built-in Dishwasher
Need Help !!!!
This is pxl8tr and I solved the problem by cycling the timer through, and the geared timer linkage automatically aligned with the soap dish!
Mar 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Open Questions:
Dishwashers Logo
20 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Michael Thomas
Michael Thomas
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
