Question about Kenwood KDC -X815
Faceplate won't close
This morning I got in my car to find my Kenwood KDC-X815 faceplate rotated half way like it does when changing CDs. Usually it does this for a few seconds when I turn off my car, presumably to give the opportunity to remove it if desired. When I cranked the car, the faceplate rotated to the open operating position but appeared to have no power. After a few seconds it rotated to halfway again. Taking the faceplate off and reattaching didn't seem to help. I also hit the reset button. I could hear the various moving parts in both the head unit and the CD changer under the seat moving, but this also had no discernible effect. Any ideas or suggestions? In all my research I saw that replacement faceplates can be purchased. Will those work with what I already have installed? Thanks for any help you can offer.
    Problem Solver:
  • 11 Answers
Alot, of the radios have a common problem with the connection from the radio'sFaceplate won't close - 2.gif detachable face. What happens is corrosion builds up on the connectors between the pin and the connector itself. Sometimes you can clean it off with a small file. Also, some KENWOODS with the motorized face are known to have a problem with the ribbon cable connecting the face plate to the main board. The last time I repaired one I called KENWOOD2.gif and aquired the cable for about 65 dollars, what the problem is, is the cable is wrapped around a plastic white spindel with a high tension spring and places alot of pressure on the cable from the wear and tear of the face opening and it will cause strange problems such as: turning on and off, some buttons working while others don't, the display partially turning on and off, and the face to act peculiar and flip down halfway. In addition, sometimes the face open and close switches go bad, but I've never had to replace them yet. .
Posted on Dec 16, 2007
Need to get the security code for Kenwood KDC-608OR
ok I just found this info online and they say it came from the service manual for that stereo so I hope it helps:
You will need a Kenwood RC-410 remote control. This remote works on KDC-519, KDC-X859, KDC-319, KDC-4019, KDC-MP919, KDC-X759, KDC-419, KDC-X459, KDC-MPV619, KDC-MPV7019, KDC-2022, KDC-2022V, KRC-435, KRC-535 and KDC-X959
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Above information source = http://techbybucky.blogspot.com/2008/01/how-to-reset-security-code-on-kenwood.html
Jun 19, 2011 | Kenwood Car Audio & Video
Whats the code to unlock my kenwood kdc 7011 cd player ?
acan't get the code for my kenwood KDC-X815 thank you
"Alfaro"
Sep 16, 2009 | Kenwood KDC-MP528 CD Player
Kenwood KDC-MPV 7019 code
Kenwood Code reset for KDC-MPV7019: (remote required)
1) Turn on the car.
3) Press >>| and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>| key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>| key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>| key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>| key on the faceplate.
MANUAL for the same radio
Jan 15, 2009 | Kenwood KDC-MPV7019 CD Player
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
Kenwood KDC-MP2035 security code
yo tengo un reproductor kenwood kdc-mp2035cr pero este no me reproduce nada solo me sale un mensaje que dice protect y no me deja hacer nada ni colocarle nada por el auxiliar
Jun 05, 2008 | Kenwood KDC-MP2035 CD Player
Kenwood excelon kdc-x815 display screen no power
recently bought a kenwood kdc-815 car radio from a swamp met. bought it with no security code need security code
Apr 08, 2008 | Kenwood KDC -X815
Kenwood KDC-519 Faceplate Problem
Detach the faceplate and look at the electrical contacts on the back of it for damage/dirt - you can spray it with electrical contact cleaner. Do the same to the contacts on the head unit - it sounds to me like one or more of them are a bit loose or otherwise not working properly.
Feb 23, 2008 | Kenwood KDC-519 CD Player
KDC S3007
Hi bacbeats,
You nered to clean the contacts on the main unit and the faceplate, evidently you have contamination keeping the power from getting from the main head unit to the faceplate.
Nov 21, 2007 | Kenwood KDC-S3007
Kenwood KDC -X815 Logo
334 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
