Panasonic PT-53WX52F rear projection powers off after 10 seconds
When I turn it on, it takes takes about 9 seconds for the screen to display anything, then it shuts off and the little red power light keeps blinking 3 times.
  • Anonymous Mar 13, 2008
    I have that same problem.
Convergence problem on panasonic rear projection TV model PT-53WX52F
the PT47WX42 Convergence repair kit from also works for your model. The kit contains the ICs, resistors and the CD with instructions.
Sep 21, 2010 | Panasonic Televison & Video
Hello need help on tv set
SHORT is on the 140 volt line--usually the horizontal output transistor is shorted, and there may be a simple reason for this.
Let me know if you are able with help to test the part indicated. I know the best way to work on this set safely and quickly.
I am in San Diego, and my name is Steve.
Jun 04, 2010 | Panasonic PT-53WX52 53" Rear Projection...
Having problem with my Panasonic TV.
hello Plug the power cord back into a properly grounded wall outlet. Then press the POWER button on the projection display or the
remote control to turn the power on
While pressing the VOL- button on the projection display,
hold down the PIP or SPLIT button on the remote control
simultaneously for more than 5 seconds
When the lamp time reset procedure is complete, the
above screen will appear. (This screen may be different from
the actual screen
When the lamp time reset is complete, the LAMP
indicator goes out.
Jan 18, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Screen turns to a red color after 10 min 9( not the bulbs)
you might need a new color wheel, id get a second opinion on that.
Oct 01, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Panasonic PT-53WX52F Color blue adjustment
most likely the two convergence Ics need to be replaced. They are STK392-110 you can get replacements at the following link with free instalation instructions with pictures.
Jul 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Hey Beestergirl, I just had my tv fixed for 385.00
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
High def tv: We replaced the lamp unit, but don't know how to reset hour meter
turn the TV power on the projection display or remote control.while pressing the volume button on the projection display hold down the PIP or split button on the remote control simultaneoulsy for more than 5 seconds.
Dec 30, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic pt-51hx41e tv screen codes
I found this on the net let me know if this works for you Once you are in service moce on a Panasonic you must continue through all steps to the end to exit. It starts with the B parameters, then C, S, and M, then you can exit by pressing power and action ON THR RECIEVER for 2 seconds. The TV will turn off and come back on on ch3 with sound. BTW, you advance thru the menus by pressing power on the remote.
Oct 05, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
351 people viewed this question
Top Televison & Video Experts
